DIFF in pajero cracking
Submitted: Tuesday, Mar 22, 2005 at 19:28
allaussie
having trouble with the diff in 90 mod jero cracking around the weld from the factory!!!!!! wots the deal cant the japanese weld or wot!!!!!!
Reply By: Mad Dog (Australia) - Tuesday, Mar 22, 2005 at 20:01
It's common for the weld around the axle housing below the spring
seat to fail on coil models 88 on, usually a result of heavy loads and rough roads. Don't know about the diff cracking though.
103474
Follow Up By: Mad Dog (Australia) - Tuesday, Mar 22, 2005 at 20:02
By the way, have the mod done... supports under the housing.
361004
Follow Up By: allaussie - Tuesday, Mar 22, 2005 at 20:10
ray i'm looking at bracing the diff from the bell thru to the shocky mounts hope it will work will be useing 1 inch plate and profiling it to suit the diff cheers chris if in
brisbane i will shout you a cold one cheers angain chris
361007
Reply By: Willem - Tuesday, Mar 22, 2005 at 20:38
I met a bloke once in
Alice Springs. He wanted some info on a certain track which I gave him but insisted that he take care as there were a few bad
washouts. He ignored my advice and was sitting on 80kmh on the track in a '90 Pajero. He hit the washout at that speed but could find nothing wrong afterwards. About 100km further on just past Kings Canyon, the whole axle housing came away from the rear diff. It snapped off. Oh what a mess. He wasnt a Happy Chappy and was stranded there for a couple of days. Also cost a pretty penny to get back to the Alice.
103475
Follow Up By: Footloose - Tuesday, Mar 22, 2005 at 21:20
When anyone gives me advice like that I spend the rest of the journey looking for the problem area. In fact I always make a point of talking to the locals wherever possible to try and get advice. My motto is "a wise man learns from the mistakes of others". Sounds like the other guy was a 4wd terrorist not tourist :))
361018
Reply By: Groove - Tuesday, Mar 22, 2005 at 21:28
Mine gave way completely, 90 Model pajero. I ended up stuck in the middle of the
simpson desert for 7 days, quite an ordeal.
Michael from North Shore Four Wheel Drive has seen quite a few come through his workshop. He sent phots etc to Mitsubishi at the time but they never acknowledged any problem.
Mine wasnt overloaded but I did have a long range
tank and this probably contributed to the problem.
They can be reinforced, Michael mentioned laminating.
103492
Reply By: Martyn (WA) - Tuesday, Mar 22, 2005 at 22:23
Allaussie,
For what it's worth I doubt it will be the actual weld cracking it will more than likely be the heat effected zone adjacent to where the weld is. Using the correct preheat if necessary, the right amps and the correct consumables are critical to getting a good strong weld, ainch of six mm fillet weld is good for lifting a tonne. There is something wrong with one of the three things mentioned above for the welds to be failing like they are. Just my opinion forumites, your may vary.
103503
