3 inch springs on rancho rs 5000's
Submitted: Monday, Mar 28, 2005 at 16:48
ThreadID: 21553 Views:2239 Replies:1 FollowUps:0
hey people was just wondering if i put 3 inch heavy duty springs with rs 5000's on my short gq will i have to change the castors or will it be fine. also does anyone have problems with the rear suspension sagging.i have rs 5000's on 2 inch king springs, if so what can i do about it. has anyone put 3 inch springs on rs 5000's if so can someone let me know.
cheers.
Reply By: Member Eric - Monday, Mar 28, 2005 at 17:09
For starters 3 " springs are custom , not off the shelf item. You are really starting to go hard on uni joints also . You can fit a kit to drop the crossmember , but at 3 " you are pushing it. If you wish to spend money on adjustable top arms , you will be ok. You will also need adjustable pan ard rods to correct the diff to center again.
I dont think you should go the ranchos , as they are really desighned for light Jeeps. You will find the adjustments next to useless on a heavy 4by. Anything off full hard adjustment will make the car so bouncy that it will be almost undrivable. You want a bill dollar shocker , go a Koni .
AnswerID: 104035
