pajero oil sender unit
Submitted: Sunday, Apr 03, 2005 at 07:12
jay039
I have a 1997 NK pajero which the oil light dose not work on
I can not locate the oil sender unit dose anybody know where it is
Reply By: herkman - Sunday, Apr 03, 2005 at 09:17
Sorry I do not know where it is, but if the unit is bad, trying earthing the lead from the sender.
The light should then light up, if not you will have to look elsewhere.
I presume you have checked the bulb itself.
Herkman
104878
Reply By: jay039 - Sunday, Apr 03, 2005 at 09:42
Yes i have checked the bulb
I forgot to mention that its a turbo 2.8 diesel
104890
Reply By: 80scruiser - Sunday, Apr 03, 2005 at 09:48
Does it have an oil guage? I replace alot of sender units in the Paj diesels.
They are located passengers side of engine right at the front and up high near the manifold.
Hope this helps.
P.S. I'm running off memory here.
104893
Reply By: jay039 - Sunday, Apr 03, 2005 at 10:04
yes oil gauge is still working but oil light is not do they both run off same sender
104898
