navman pin
Submitted: Wednesday, Apr 20, 2005 at 20:49
ThreadID: 22239 Views:1592 Replies:2 FollowUps:0
how do i get the oz ce to se my maps on my flash card iv loaded them on ie: rasta map sheet but when i click on find map i find the map file but it wont open says cant find the image i know in oz explorer you can import maps and change the drive they are on but how do you doit on ce
Reply By: Ants - Wednesday, Apr 20, 2005 at 21:21
Ozi CE needs a specific image type.
Go to the website - they have a utility you can download that is used for the conversion.
AnswerID: 107597
Reply By: Never ending journey - Sunday, May 15, 2005 at 13:16
Rex to get the Navman to see the files for Oziexplorer you need to do the following. First convert the file using the utility 'Image to OZF utility' found on the OziExplorer website. You then 'Load and Calibrate' this into the main program on your PC. When you then save this calibrated file it creates a 3-4 Kbit instruction file that tells your program on the PDA or Pocket PC how to read the file. The two files, Ie the converted Raster file and the smaller instruction file must be saved together on the storage card. Just create a folder called maps and put all the files in that. Hope this has been some help.
Dean
AnswerID: 111330
