aspect ratio
Submitted: Thursday, Apr 21, 2005 at 15:58
darbi
Ive searched but cannot find ...
Can anyone offer any thoughts on putting 70 series tyres on a Prado which has 265/65/17 stock? Pros and cons appreciated
thanks
Reply By: GO_OFFROAD - Thursday, Apr 21, 2005 at 18:02
You will be one of many who has already when you do, speedo will change by a couple of km per hr.
107702
Follow Up By: Exploder - Thursday, Apr 21, 2005 at 18:18
Gday Darbi
I assume teas are the 2 tyre sizes you r looking at?
Load Index Ply OD in mm
265/65R17 112 776
LT26575R17 121 10 803
If so you r as you can see you get a little more hight out of the tyre it has a 10 ply rating which r both bonuses and it has a higher load index so you r good on the insurance side too. It will put the speedo out by a small amount but not much.
Note# The OD and the width of the tyre will change slightly depending on manufacturer even know it says 265/70R17 it may be slightly smaller or bigger.
364599
Reply By: Exploder - Thursday, Apr 21, 2005 at 18:23
Sorry mate that little table didn’t work out like I had planed
You may still be able yo decipher it thou.
107705
Reply By: geocacher (djcache) - Friday, Apr 22, 2005 at 00:52
Aspect ratio refers to the ratio between the chord of a wing and the span of the plane/glider. What's it got to do with tyres?
Dave
107757
Follow Up By: Member - bushfix - Friday, Apr 22, 2005 at 14:27
G'day Dave,
ratio of tyre section height to tyre section width.
ie 30 = height is 30% of width.
364693
Follow Up By: Exploder - Friday, Apr 22, 2005 at 16:10
Hay
I see we have an aerodynamics buff amongst us.
364708
Follow Up By: geocacher (djcache) - Friday, Apr 22, 2005 at 22:52
Just a little.
Dave
364756
Reply By: darbi - Friday, Apr 22, 2005 at 14:17
thanks to you both .. the table was fine. If thats the only drama, I think I'll take the plunge.
thanks again,
Darbi
107819
