Replacement steel wheels
Submitted: Friday, Apr 22, 2005 at 00:40
ThreadID: 22277 Views:3256 Replies:4 FollowUps:7
will a set of steel wheels from an 80 series GXL (rigid suspension) fit my 78 series troopy ?
thanks,
Terry
HZJ78 camper
Reply By: Member - Davoe (WA) - Friday, Apr 22, 2005 at 01:53
No
AnswerID: 107762
Follow Up By: Pterosaur - Friday, Apr 22, 2005 at 10:20
Thanks Davoe, what's wrong with them - offset ?
FollowupID: 364669
Reply By: crfan - Friday, Apr 22, 2005 at 10:31
Don't 78's have the five stud wheel patten ?
AnswerID: 107791
Follow Up By: Pterosaur - Friday, Apr 22, 2005 at 10:35
No - 6 studs
FollowupID: 364671
Follow Up By: Member - Davoe (WA) - Friday, Apr 22, 2005 at 16:03
??? 78s have 5 studs and 80s have 6 hence my answer
FollowupID: 364705
Reply By: SAoffroader - Friday, Apr 22, 2005 at 14:25
Terry
78 series has a 16x5.5 rim with a 20p offset where as the 80 ser has a 16x8 with a 0 p offset so its a matter of trying you will push your offset out buy about35 mm
SAoffroader
AnswerID: 107820
Reply By: Member - Phil G (SA) - Friday, Apr 22, 2005 at 15:44
Terry,
Your vehicle is a 75 series, not a 78 series. (you have leaf springs all round and 6 stud wheels).
80 series rims won't fit because they have too much backspacing for your troopie.
AnswerID: 107831
Follow Up By: Member - Phil G (SA) - Friday, Apr 22, 2005 at 17:33
Terry,
Just looked at 70scool and your question there states its a 2000 model which is indeed a 78series and they were all 5 stud. Just check your compliance plate to be certain (and you might want to count your wheel studs again :-)))
80series wheels will not fit.
105series rigid front end wheels will fit nicely.
phil
FollowupID: 364718
Follow Up By: Pterosaur - Saturday, Apr 23, 2005 at 09:29
Phil,
1. 70sCool question about 2000 model is not mine (similar tho') :-)
2. Coils at front, leaf at rear, 6 studs (on each wheel too :-))
3. Mine is 2003 model
4. I thought troopies (recent ones at least) were 75 series or 78 series with the 78 being the later model - am I wrong?
5. Compliance plate says HZJ78 - 78 series???
6. Knew about 105 series wheels (from 70sCool), but knew of some 80 series wheels for sale, did not know of suitability, or difference from 100,105 series.
regards
Terry
2003 Troopy camper
FollowupID: 364781
Follow Up By: Member - Davoe (WA) - Saturday, Apr 23, 2005 at 14:21
pt now that is odd ,barring the possibility that you cant count as a 2003 model with coil springs it should be a 78 series with 5 stud wheels. So I am assuming it has had some kind of retro fit I cant think of why it might have been done Does it also have the thicker axle studs? or the old thinner ones to? all I can tell you is because of the offset wheels off of a 78 wont fit a 100 as you have an oddball the best way might be to try (your local tyre place should be able to help specially if you are a good customer
FollowupID: 364792
Follow Up By: Pterosaur - Saturday, Apr 23, 2005 at 14:51
Hmmm
man, do I have a red face ! seems I can't count and am probably blind to boot !
5 studs only !!!!!!!!!
Dunno where i got 6 from
apologies about wrong info and confusion to all - have a LOL on me !!!
(back under my rock)
Terry
FollowupID: 364796
