evacool duel temp
Submitted: Sunday, Apr 24, 2005 at 14:48
hedevil
Hi all just got a great deal on a 47 DT evacool at the
brisbane tinny and 4B show. Any way ,a ny owners out there what, would be a good setting to have the freezer section working, and what is a good temp to store frozen foods and what would or should give the fridge section with divider in place. appreciated feedback....Max
Reply By: Member - Oskar (Bris) - Sunday, Apr 24, 2005 at 17:35
I have to run my RF47 (dual temp) on 1 or 2 or it gets too cold.
Experiment with bottles of
water to find the best settings (before you go bush).
Buy an electronic temp gauge and try it in various spots in the fridge <$40 at Jaycar etc.
Oskar
108015
Reply By: Steve - Sunday, Apr 24, 2005 at 19:31
Looking forward to your experiences with this unit ...was very impressed at recent show ..but alreadyhave a 21 Engel(freezer) and a 39 Engel as cool fridge..would like to know how your unit stacks up !!
108025
Reply By: derraux - Tuesday, Apr 26, 2005 at 17:48
Hedevil
You should set your fridge temp to whatever you find adequate generally around 4deg the the freezer section should be around -10deg from memory which is adaquate for
camping most household freezers alot more powerfull and run at about -18 to -20
Derraux
108280
Follow Up By: hedevil - Tuesday, Apr 26, 2005 at 19:51
Thanks all, one question I do have, to add is the power pack that came with the unit (blue) when the lighter end goes into the socket it tends to push itself out and have found no power a couple of times while experimenting. any ideas??/ I will contact Evacool to find out if my concern is a one only or common, the spring in the end of the connection does appear quite strong...Max
preparing for the 6 months on the road with great enthusiasm.
365062
Follow Up By: derraux - Tuesday, Apr 26, 2005 at 23:31
Hedevil
This is a common problem with evakool power cords the spring is too stiff has been a problem for some time, because the amp draw on boost the spring needs to be rated so, they keep saying the problem has been fixed, should only happen with leads over 6 to 12 months old all new fridges iv'e seen have had soft springs, just call them they should send a new spring in the post.
Regard
Derraux
365107
Reply By: hedevil - Saturday, Apr 30, 2005 at 13:41
yes true with the spring, rang evacool and posted two in mail next day. Although i must say I have twisted the connection as inserting it and it hasnt come loos e since.
thanks all.....max
108929
