1989 ford ltd coded radio
Submitted: Monday, May 02, 2005 at 15:51
seagull
hi! i have a 1989 ford da ltd that has a coded radio casette now the proble i have is that the local ford dealer dos'nt want to help me with a code for it is there anyone that know how to tell what the code is on this unit please email me direct if you don't want to post it in this
forum
Reply By: DukeAtty - Monday, May 02, 2005 at 16:45
there is no easy way to tell the code... they are coded accordingly...
if its an AWA with a joystick on it for tuning speakers then a modification can be done internally so it never asks for a code again... $20 modification if you are in
Adelaide... if not then most good techs can bypass the code...
109245
Reply By: Utemad - Monday, May 02, 2005 at 17:54
If it is the joystick model described above it is a very simple job with a soldering iron to remove the code for good.
There is an area of about 5 pairs of solder pads on the circuit board which are bridged in a certain way. If you remove all of the solder bridges you will remove the code.
The description above of the amount of solder pads is probably not 100% accurate. It has been a few years since I have looked at one but you get the idea.
While you are in there re solder all the dry solder joints. That model will have plenty of them.
From memory you only have to remove the bottom cover to access the circuit board.
109256
Reply By: seagull - Monday, May 02, 2005 at 18:21
no iot's not the joystick model i hav'nt had it out of the car so i have no idea of the make bit i can tell you it has numbered buttons 1 to 6 down the right hand side
109265
Reply By: Member - Matt Mu (Perth-WA) - Tuesday, May 03, 2005 at 12:44
Seagull, that sounds like its the Phillips model and the service manager at
Metro Ford in Brissy used to just use the vehicle VIN and engine numbers to look up his data base. I believe ford radios are assigned a code from manufacture and it stays with it. Unlike Toyota ones that the dealer can use a generic code to reset the unit and they cannot give this out to the owner. You must bring it into the dealer and pay the $80 to have it reset.
I would try another Ford dealer (with all you details, rego and vin numbres) and see if you get the same lazy response, but I dont expect you would. There shouldnt be any reason they cant help you.
Goodluck
Matt.
109436
Reply By: Wilgadene - Tuesday, May 03, 2005 at 22:41
Mazda used the last 4 digits of the VIN, maybe the ford one is the same
Kev
109542
