Codan HF Automatic aerial
Submitted: Tuesday, May 03, 2005 at 13:13
ThreadID: 22606 Views:2327 Replies:4 FollowUps:5
G'day Fellow Travellers,
Just wondering if anyone knows of where i could find second hand HF aerial to suit codan 8525b or 8528 radios.
Troopytrek.
Reply By: Member - Banjo (SA) - Tuesday, May 03, 2005 at 13:48
Try Alex Daws in central Victoria - might have one or know of one - 0417 566 022 - he supplies and installs used Codan HF systems.
AnswerID: 109444
Reply By: Member - Davoe (WA) - Tuesday, May 03, 2005 at 16:09
why? I have used multi taps and found them better and cheaper that auto tune how many channells do you want to use? dont forget auto tunes dont last long during bushwork at least you can pull a multi tap off
AnswerID: 109473
Follow Up By: Member- Rox (WA) - Tuesday, May 03, 2005 at 19:30
Mine sits on the rear so It doesn't get damaged, I take the areal off when in overgrown bush.
FollowupID: 366099
Follow Up By: Footloose - Tuesday, May 03, 2005 at 21:27
Ahh, Davoe, you've yet to see the light. (Min Min ?). You are correct, a whip is much longer lasting if you go around assaulting trees and service station lights.
However a whip doesn't have an inbuilt preamp. You can't really scan several frequencies to listen for a selcall.
Ever changed frequencies at night....in the rain...or a sandstorm. I have , give me an atu any day.
Go around making statements like this " at least you can pull a multi tap off" and even Kalgoorlie types will start to look at you funny :))))))))
FollowupID: 366128
Follow Up By: Member - Davoe (WA) - Wednesday, May 04, 2005 at 02:04
If you used hf you would know night use is difficult due to indon boat people making it near immpossible. My experience is from using them in thick bush while bushbashing for work with a company that has used them for as long as they have been around and instead of mucking about just uses what works not just just a bit of recreational use
FollowupID: 366163
Follow Up By: Footloose - Wednesday, May 04, 2005 at 08:43
Davoe, why do you assume that I just use em for a bit of recreational use ? What makes you think that I haven't been using HF in the bush before you were born ?
Before assuming anything, give people the benefit of the doubt .
FollowupID: 366179
Reply By: Old Gold - Tuesday, May 03, 2005 at 21:00
G'day Troopytrek,
You could try Roger William's in Kalgoorlie. I think a multi tap would be the way to go
Cheer's
AnswerID: 109511
Follow Up By: Member - Davoe (WA) - Tuesday, May 03, 2005 at 21:11
nuh he shut up shop a few months ago
FollowupID: 366123
Reply By: brian - Wednesday, May 04, 2005 at 08:01
could try vks737 website they sell secondhand bits and pieces
AnswerID: 109569
