UHF radio/speaker problem
Submitted: Thursday, May 12, 2005 at 17:10
Cobradave
I use a Uniden UH013 radio and connected an external GME SPK04 speaker. Cannot get enough volume out of this speaker. I suspect it is an 8 Ohm speaker and should be a 4 Ohm speaker for this radio. Can anyone confirm this or have another idea please.
Thanks, Dave
Reply By: Bros - Thursday, May 12, 2005 at 20:52
Cobradave,
I have a 5w, 4ohm (thats what it says on the back) speaker hooked up as an external speaker for my GME TX 3000 and it works like a beauty.
Bros.
111078
Reply By: PandJ - Saturday, May 14, 2005 at 15:29
Hi Dave,
The GME SPK04 speaker that you are using is in actual fact an 4ohm speaker.
I suspect it could be the size of the speaker. The GME SPK07 and GME SPK09 are
8 ohm speakers.
Have a look in the book at the specs for the correct ohm's for the radio.
Type the following in your search engine and have a look, gme electrophone speakers.
Good Luck, PandJ
111270
Reply By: Cobradave - Saturday, May 14, 2005 at 16:59
Unfortunately the manual makes no reference to either the radio speaker Ohms or the external speaker Ohms.
Dave
111275
Reply By: Cobradave - Monday, May 16, 2005 at 13:01
Problem solved, Uniden tech. support advised that I should be using an 8 Ohm speaker. Makes no sense to me being of a higher resistance than a 4 Ohm speaker, nevertheless it did solve the problem. Thanks for your help.
Dave
111438
