What spares to take on the CSR???
Submitted: Saturday, May 21, 2005 at 21:08
Tony J
OK, Down to the nitty gritty. 80 Series Std Cruiser. I have spare fanbelts, air con belt, rad hoses and clamps, radiator stop leak, "knead it" metal repair stuff, puncture repair kit, tubes and tyre pliers, spare tyre and a spare casing, welding gear, soldering gear, dual battery,jumper leads, tools, spare fuses and electrical wire, multi metre, 5 metres of fence wire (can be very handy!!), 1 x spare wheel bearing, 1 x spare uni joint,
HF radio - VKS737(antenna being repaired),
fuel, oil & air filter, spare engine & diff & p/stear oil, brake fluid, repair manual, 2 x spare ctns beer(maybe need more?), heaps of
water, food and
fuel. Vehicle in tip top shape. What else should I take as spares? Have rung ahead to organise
fuel. Only 4 weeks to wait!! I can't help but think I have overlooked something. We have done a lot of tripping about but after the recent tragedy out there I want to be sure I've thought of everything.
TIA
Tony J
Reply By: Member - DickyBeach - Saturday, May 21, 2005 at 21:33
How're your shocks? There are 100,000,000,000,000,000 corrugations and if you hammer it you'll pay for it.
112239
Reply By: fisho64 - Saturday, May 21, 2005 at 21:43
300 k's has been graded hasnt it?
112242
Follow Up By: Coops (WA) - Saturday, May 21, 2005 at 22:19
about 100 km's I believe and not noticeable is the report I got recently
368566
Reply By: Trekkie - Saturday, May 21, 2005 at 22:07
We did CSR two years ago. Landcruiser and 3 Patrols. Several punctures only and no one had any problems. Apart from its remoteness, the CSR is not really too difficult if you take youir time. Corrigations on
Cape York are worse than CSR.
Most important thing is to ensure spinifex is cleaned out frequently. I would suggest you have several days at Derba Springs to rest up - its a truly beautiful spot.
112245
Reply By: Member - Davoe (Widgiemooltha) - Saturday, May 21, 2005 at 22:10
fuel hóse both half a meter of supply and return pluss male - male joiners and hose clamps, a must for cross country driving maybe not neccessary for csr I understand
112247
Follow Up By: Tony J - Sunday, May 22, 2005 at 18:07
Thanks - forget that. I take some heater hose as
368601
Reply By: Footloose - Saturday, May 21, 2005 at 22:57
Dune driving can place a load on your radiator and clutch. Also have you had the front and rear bearings done recently ? Got the CSR "Bible" (Travellers Guide) so you don't end up in one of the "glue pits " ?
UHF radio and sand flag ?
112253
Follow Up By: Tony J - Sunday, May 22, 2005 at 18:10
Got the flag and UHF, Wheel bearings and CV's done in the last 2 months. Got more books and maps than I can read. Also got the GPS.
368602
Follow Up By: Footloose - Sunday, May 22, 2005 at 18:15
Sounds like all you need to do now is to have a great trip :))
368605
Reply By: Member - Banjo (SA) - Saturday, May 21, 2005 at 23:16
Apparently those in the know have some way of putting out a spinifex fire underneath - extinguisher not good enough - apparently a pump style garden sprayer with 6 L of
water and the metal wand is the way to go - the fire can be right up under in hard to get spots. A front and rear shocker seems wise - even careful folks I know have trashed shockers and cracked diffs........
112256
Reply By: V8troopie - Saturday, May 21, 2005 at 23:55
Tony, the one spare part you need most likely is not packed, its the way murphy plans it.
A spare thermostat perhaps, and a waterpump rebuilt kit unless you checked it recently.
Maybe spare wheel nuts & studs, spare oil plugs and other vital little things like that which would stop you should they come loose and fall off.
Consider also how you would fix a broken spring - I have met a troopie on the CSR which had brand new springs and one was broken already. Also consider how you would fix a broken steering damper, my troopie is undrivable (above 10kmh) without a good damper.
I hope to travel the CSR again sometime, its nearly 15 years since I went up the full legth of it. Thinking about that, we had to detour the last
two wells due to flooding and I wish I had a GPS (they were not common then) or the paper charts for the area we had to traverse to get out. Laptop computers with nav software and GPS would make such a task far less worrying than it was back then. All we had was a mud map and the faint track of a traveller who came the other way to follow.
Have a good trip, if you are stopping for a break at Durba springs a solar shower bag might be useful as the
water we found in pools up
the gorge was icy cold.
Klaus
112260
Follow Up By: Member - Davoe (Widgiemooltha) - Sunday, May 22, 2005 at 03:40
thermostat can be fixed temporeitroly by removing it
water pumps can have the load reduced on them by emptying the
overflow and droping the level to just above the fins (wont effect cooling) but will stop them from leaking and they dont need steering dampers - underground vehicles routinely have them removed when they fall off and I have only ¨seen springs break ater being coated in hypersaline mud and hammered accross pit floors (csr x 10) for a couple of years
368573
Follow Up By: Footloose - Sunday, May 22, 2005 at 08:55
The CSR can break springs, especially some aftermarket ones. I've seen the results of overloading. Not common but it does happen. I guess that you can break anyhing if you don't treat it right.
368576
Reply By: Member - Jim - Sunday, May 22, 2005 at 06:11
Tony J
Consider a clutch slave cylinder kit, when we did our trip in 1999 we had no punctures between 2 vehicles and campers, we broke nothing more than a driving light bracket, we had to use the clutch kit and we had one battery fail out of six.
Have a good trip, it seems you have most things sussed, take your time as it is easier on you, your passengers and your vehicle.
You can go days without getting out of 1st, 2nd and 3rd gears.
Regards,
Jim
112265
Reply By: mfewster - Sunday, May 22, 2005 at 07:31
One of the best little gadgets you can have is a Clampit, should be in every kit. Small. Light. Can make pipe clamps of any size from
fuel lines to exhaust brackets. and fix all sorts of things; tent poles, axe handles. You just wind wire around the items, then use the Clampit to to tighten it up and lock it. Have even seen one used to fasten
the springs together when a U bolt went
112267
Follow Up By: Tony J - Sunday, May 22, 2005 at 18:13
OK This sounds interesting. I have never heard of it. Where would I look for one of these? Remeber that I've never heard of it let alone seen one.
368604
Follow Up By: mfewster - Sunday, May 22, 2005 at 18:37
Try this website
http://practool.com/
You can see a demo and buy them online with a CD showing how to use them. It's really very simple
I came across them at the
alice Springs Show. Quite a few 4wders around here carry them. I keep finding new uses for
mine. Have seen a snapped axe handle rejoined and working just fine. Very neat and strong.
I'm not an agent- promise.
368610
Follow Up By: Richard Kovac - Sunday, May 22, 2005 at 19:24
Just ordered one and some wire, looks good, just the thing you need in the tool box
Thanks for the link
Practool
Regards Richard
I,m not a farmer just look like one
368613
Reply By: Barnray - Sunday, May 22, 2005 at 07:39
Tony you haven't mentioned it, you may have it, but I would think that a epirb would be on the top of the list. It is self contained so if all else fails push the button and wait for rescue. Barnray
112270
Follow Up By: Tony J - Sunday, May 22, 2005 at 18:15
Got that thanks. I seem to have missed listing some things that are always stored in the car!
368606
Reply By: brian - Sunday, May 22, 2005 at 07:47
If your fencing wire was around 8.8 metres it could double as emergency aerial for hf would give you 8022 commonly used channel,just a thought,but would be best to check with vks737 to get exact wire length and also to see if fencing wire is suitable or if it needs to be copper wire.have a great trip.
112271
Follow Up By: Footloose - Sunday, May 22, 2005 at 08:52
The length is 29'6" approx, whatever that is in metric. That will give you 8022 in an emergency.
368575
Reply By: Peter 2 - Sunday, May 22, 2005 at 08:37
I'd second V8 troopies comments, been 13 years since we traversed the CSR in a troopy.
Suspension and cooling sytems are the most critical and will cop the biggest hammering. At least carry one front and one rear shock as coil sprung vehicles really give them a workout, it won't stop you but will make it more comfortable/controllable. You seem to have most items covered, take your time and have a safe trip.
112273
Reply By: Tony J - Sunday, May 22, 2005 at 18:24
Thanks all, Some good suggestions in there, especially that 'clampit' gizzmo if I can find one! Only three weeks 5 days 17 hours to go - but who's counting!!! Iv'e got most things, we have done some very interesting trips over the last 7 or 8 years. I think I'm a bit paranoid this trip for some reason. In all the travels we've done, only had 1 major hiccup - that was when the turbo oil return line broke out of the sump at Captain Billys Landing! I suppose I must be thinking it must be my turn for trouble this trip.
Thanks again all
Tony J
112323
Reply By: Wayne (NSW) - Sunday, May 22, 2005 at 20:23
Tony,
What about a air pump to fix the flat tyres.
I am also making a list and checking it twice, but every time I cross off one item I put two more on and I leve next Thursday.
Wayne
112346
Reply By: Trevor W(Brisbane) - Monday, May 23, 2005 at 15:59
Hello Tony
We are leaving for the Canning on the 31st July and should be starting at
Halls Creek on about the 6th Aug for approx 16 days
If you are in
brisbane my e-mail is tecewebb@bigpond.net.au and I have a video of a friends trip he did sept 2003 which you might want to have a look at.
A couple of things
there trip was a tag along
They broke
1. Front Shocky top mounts on IFS Cruisers.
2. Rear shocks on Ford Explorer.
3.U-bolts on springs on rear of ford explorer
Other than that they said to be prepared for a long trip that you must take your time.
4. things I am carrying that I couldnt see on your list
Take a couple of lengths of threaded rod metric and spare nuts and washers that you can get from the hardware or bolt place at least 12mm,10mm,6mm
This can then be bent into U bolts or cut to any length to make bolts.
Take a can of Aero Start if your car is diesel.
I carried an Exhaust Jack through the Simpson as it was easy to Jack Car up on sand and put grass etc under wheels to drive out of sand bogs
I also carry some 50mmX50mmX3mm sq mesh 300 wide and width of bullbar strapped to bullbar but can easily be used a bog Mat under wheels or just as pot rest over fire place. 2 pices easily strap to bullbar and also protect front from stones flying up a bit.
If you get back before 31st July could you e-mail us on what
water and fuel situation was out on the track. Any thing else you want to know send me an E-mail How did you organise fuel.
Trev Webb
112435
Follow Up By: Tony J - Thursday, May 26, 2005 at 18:11
Hi Trevor
We are travelling south to north. We wont be
home 'till 2 Aug.
How did we organise fuel? We hold 150 litres and are carring another120litres. Fuel then will be purchased at Parnngurr Aboriginal Community (used to be called Cotton Ck) ph 08 9176 9009. 82k west of
Georgia Bore on the edge of Rudall Nat
Park. They like travellers to ring ahead and leave their name. They said no problems with deisel.
Then at Kunawaritji Community (near
well 33), ph 08 9176 9040. Once again no probs with deisel, I didn't ask about ULP.
The fuel we are carrying gives us 1500k range at our worst ever consumption rate ( and that was towing a trailer off road - no trailer this time)
Have a good trip
Tony J
369210
Reply By: AdrianLR - Monday, May 23, 2005 at 22:12
They may already be in your normal kit but just in case....
Spare headlight/driving light globes
Cable ties
Depends what you're
camping in - spares/repairs for that.
For uncommon repairs, you may have the spare part but do you have the
tools to fit it?
Support vehicle to carry all the stuff everyone's suggested!!
Have a great trip.
Adrian
112509
Reply By: Austravel - Tuesday, May 24, 2005 at 10:57
Geess how do you guys carry all this weight. I take some gear but if you added up the weight of all the extras above it could be a couple of hundred kilos with second spare tyre, shocks, etc, etc, etc. I take a second spare wheel and the basics but just wonder how you do it, do you tow a trailer?
112571
Reply By: Andy C - Tuesday, May 24, 2005 at 18:30
I'm with you Austravel!
I'm about to do the CSR in Aug 05 and I don't seem to get anything than horror stories!
I'll have all the basic (non-mechanic replace stuff - belts/hoses/blah blah) and will drive to the conditions and have a wonderful time!
Don't take this as unprepared - we have all vehicles up to scratch - all recovery and emergency equipment.
I think we all only hear of the "breakdowns of vehicle stuff" more than "Oh $hit - I did't take enough fuel"!
Tony, you seem extremely
well prepared - have fun, take your time, and enjoy.
112633
Reply By: mfewster - Saturday, May 28, 2005 at 17:48
Hi Richard Kovac. When you get your Clampit, i'd be interested in heAring what you think og it. I keep finding new uses.
Mike
113360
Follow Up By: Richard Kovac - Saturday, Jun 04, 2005 at 19:00
mfewster
They arrived the other day
Took them to work and try-ed them out, worked fine, easy to use great investment.
I try-ed them around some two wire hydraulic hose, they pulled they tie wire down below the rubber outer layer
Regards Richard
370305
