Flasher unit location
Submitted: Sunday, May 22, 2005 at 14:02
ThreadID: 23201 Views:7075 Replies:3 FollowUps:2
Could anyone tell me whether the trafficator flasher unit is located under the dash in the engine compartment of a 97 Nissan Patrol.
Thanks.
Reply By: dirtdodger - Sunday, May 22, 2005 at 15:00
The turn signal flasher unit on a GQ patrol is located on a bracket under the dash, between the brake pedal mounting and the steering column.
AnswerID: 112299
Follow Up By: dirtdodger - Sunday, May 22, 2005 at 15:02
If I knew how to post pictures, I would show you a piccy of the location!
FollowupID: 368587
Follow Up By: Member - Ed. C.- Sunday, May 22, 2005 at 15:05
ah, beat me by t-h-a-t much... ;-))
..I dunno how to post pics either:-(
Confucius say.....
FollowupID: 368589
Reply By: Member - Ed. C.- Sunday, May 22, 2005 at 15:02
Tomj,
The flasher unit is located under the dash (in the footwell)....
You don't say if yours is a (late) GQ or a (early) GU,
but anyway.....
In the GQ, it's to the left of the brake pedal actuator rod....
In the GU, it's attached to a bracket directly above the clutch pedal...
Hope this helps:)...
Regards, Ed. C.
Confucius say.....
AnswerID: 112300
Reply By: Tomj - Monday, May 23, 2005 at 01:19
Thanks to Dirt Dodger and Ed C for your information, much appreciated.
Tomj
AnswerID: 112384
