80 series fuel tank pressurizing
Submitted: Thursday, May 26, 2005 at 11:05
ThreadID: 23319 Views:2166 Replies:3 FollowUps:2
Has anyone ever had trouble with a 1996 petrol 80 series building up a lot of pressuer in the fuel tank? (too much pressure!)
Where do I look after the carbon canister if ther is no obstruction there?
Hairy
Reply By: bundyman - Thursday, May 26, 2005 at 11:36
Hairy,
Check the breather on the fuel cap mate. I know our work 75 Series (diesel) utes get the little brather hole blocked occasionally and then you actually starve the motor of fuel as the tank drops to about 1/4 tank - purely due to the vacuum created. With a petrol you'll have the expansion problem which mighten be able to escape hence the high pressure. Just my thoughts.
Hughesy
AnswerID: 112979
Follow Up By: Hairy - Thursday, May 26, 2005 at 13:58
Cheers for the thoughts but apparently they dont have a breather hole and are suposed to have a little pressure in them because of the fuel injection.
Thanks anyway
FollowupID: 369172
Reply By: BenSpoon - Thursday, May 26, 2005 at 11:47
Check that the fuel cap is genuine- If not, head to a wreckers. If it is, might be worth cleaning it out.
AnswerID: 112980
Reply By: Moose - Friday, May 27, 2005 at 13:31
How do you know there is too much pressure?
AnswerID: 113171
Follow Up By: Hairy - Monday, May 30, 2005 at 08:49
After unscrewing the cap I pressed the little flap down inside the filler to release some of the pressure and fuel spewed out and covered me!
Great stuff in your eyes!
FollowupID: 369607
