Fuel Tank
Submitted: Wednesday, Jun 01, 2005 at 10:27
Troll83
Hi Everyone
I want to fir a bigger second
fuel tank to my 99 GU...however I don't like the idea of spending $1000 for something that will give me a extra 40L or something. As all the GU owners know the sub
tank is very small. Will it work if you go to the wreckers and get a main
tank of a GU and replace the sub with the main? I am not sure if it will fit but if it does, I can't see why this won't work? Has anyone done something like this?
Reply By: Well 55 - Wednesday, Jun 01, 2005 at 12:26
Troll83, nah the main won't replace the aux
tank, wrong shape.
A larger replacement main
tank is the cheapest way to go and less hassels with hoses etc.
113888
Reply By: hilux bert - Wednesday, Jun 01, 2005 at 13:51
i think somebody on here had a second
tank on his hilux, it was just a main
tank that he'd put in. if i'm right can they let me know some more details cos i'd like to do the same. where do you put the muffler etc....?
cheers joel
113900
Follow Up By: Member - Jeff M (WA) - Wednesday, Jun 01, 2005 at 17:20
Yeah I've heard of people placing a main on the passenger side (reversed of course) but I have often wondered where the muffler goes then...
I've got a huge place under the back where the spare used to go that I'm interested in filling up with a
tank, I have already moved the exaust around that bit. I spose that's the advantage of the wagon, being able to put the spare on a rear carrier.
369968
Follow Up By: BenSpoon - Wednesday, Jun 01, 2005 at 18:58
Jeff-
Check out some Auto gas fitting shops. IT pretty common for them to use the spare wheel
well to locate a small gas or
fuel tank- you may be able to get hold of a cheap supplier thru them.
It may have been a one-off backwards setup, but recall seeing an EL Falcon and they replaced the
fuel tank with a big gas
tank and stuck a smaller
fuel tank in the wheel
well- though all others I've seen have been the opposite.
369985
