Holden Rodeo tyre choices
Submitted: Thursday, Jun 02, 2005 at 20:08
ThreadID: 23544 Views:6605 Replies:5 FollowUps:1
Here is a bad blue by Holden, there are only about 4 choices of tyre that fit LEGALLY to the new Rodeos (at least in Qld).
The BFG AT, a Continental AT, the original Bridgestone AT (a truly terrible tyre) and another all bitumen type of tyre.
The LOAD rating is where the bad judgement has been made, plenty of choices of tyres in the right size, but Holden have specified a weird load rating which drops the choices to the few above.
Reply By: Utemad - Thursday, Jun 02, 2005 at 21:55
You'll find that with a lot of new fourbys. Especially ones with factory mags.
AnswerID: 114153
Reply By: mik*2 - Thursday, Jun 02, 2005 at 22:32
the Bridgstone AT isn't that bad. I've got them on my car and they do very well.
mike
AnswerID: 114165
Reply By: old-plodder - Friday, Jun 03, 2005 at 08:21
Can you go for a heavier load rating?
AnswerID: 114193
Follow Up By: Dennis (Mackay) - Friday, Jun 03, 2005 at 19:06
Yes, but then the speed rating isn't right (too low).
So you end up back at square 1.
FollowupID: 370240
Reply By: Glenno - Friday, Jun 03, 2005 at 18:39
Yup welcome to the club. Hilux is just as bad. Thankfully the range has increased as from memory only the Goodyear ATR was available as a legal alternative. Then they changed from individual tyre load rating to Axle load rating which opened up the options to Coopers / BFG / Bridgies etc.
So suss out the concept of Axle load ratings. something like 1500kg per axle or something. It should be stamped on your tyre placard in drivers door jam. Tyre guys at 4'bys Moorooka said you can use either as the minimum.
Glenno
AnswerID: 114264
Reply By: cmilton54 - Friday, Jun 03, 2005 at 19:18
You are limited by load index can NOT go below that limit which normally is max load carry capacity. Can go below speed index because usualy vehicle has a speed index lower than tyre placard of possable (L) 120kms hr
Charlie
AnswerID: 114266
