Low voltage cutouts
Submitted: Tuesday, Nov 12, 2002 at 01:00
Nige
Does anyone know of the availability of an adjustable low voltage protection device that cuts the 12v supply when the battery reaches a pre-set (or fixed) level? Engel have a 10.5v and an 11.5v battery cutout for about $100. Are there any others out there that can handle the high amperage needed by chescolds to make them work efficiently? Thanks!
Reply By: OziExplorer - Wednesday, Nov 13, 2002 at 01:00
D*ck Smith Electronics have:
Low Voltage Battery Cut-Out
Kit No. K3124
Price $29.88
From website: www.dse.com.au
Ideal for car or boat when powering external accessories.
Disconnects the load from the battery once the voltage drops to a predetermined level
Adjustable drop-out voltage: 10.9 to 11.9 volts (nominal)
Can be set to automatically restore power to the load when the battery returns to normal condition
It is a simple kit to build.
8459
Follow Up By: Mikef_patrol - Wednesday, Nov 13, 2002 at 01:00
Yep, have used one of these for the last couple of years, works
well. Can adjust the cutout voltage via a variable resistor. Be aware though, that over rough roads, the variable resistor setting can change, so once you have it adjusted to the setting you require, put a dob of silicone on it to stop it moving.
TTFN
4098
Follow Up By: Oziexplorer - Wednesday, Nov 13, 2002 at 01:00
Silicone -ARGH the stuff should be banned!
Clear Nail varnish is the go. Great product clear nail varnish for so many jobs.
4100
Follow Up By: Member - Mal - Wednesday, Nov 13, 2002 at 01:00
Clear nail varnish for brest implants!!!! --I don't think so Ozi Explorer.
4102
LOL LOL
OK use nail varnish then!
"Now, where is my handbag?"
LOL
MikeF
4104
Reply By: desert - Thursday, Nov 14, 2002 at 01:00
Pink nail polish is much more in your face!
8520
Follow Up By: Oziexplorer - Thursday, Nov 14, 2002 at 01:00
Hmmm
orange is more gender and sexual preference neutral.
Why I stick with clear - nobody can accuse me of anything.
4142
