lift kit for a Navara
Submitted: Friday, Jun 10, 2005 at 10:22
Johnny B Good
g day
I would like some advice to wether or not i would be able to get a lift kit on my Navara. 2'' would be nice but weater or no i am able to would be good to find out. I have been told it is no go to get a lift kit on the Navara because of the set up on the front end
I would get a set of old emu springs any other advice on that would be great
cheers JohnnyBgood
Reply By: Truckster (Vic) - Friday, Jun 10, 2005 at 10:23
Have you tried TJM or ARB for info?
Who said its no go?
115206
Reply By: Johnny B Good - Friday, Jun 10, 2005 at 10:27
no i have not been yet something because it is independant front end
115211
Reply By: Member - Toonfish - Friday, Jun 10, 2005 at 10:44
i have a lift from arb with
suspension.
advertised 2 inch but 40mm at beats sinking to 36-8 mm front rear depends on load.
Calmimi lift 3 inch would rock but limits uptravel a bit.
any way much better ride smoother with a little weight in it.
bout 1800 installed with the works
115216
Follow Up By: Johnny B Good - Friday, Jun 10, 2005 at 11:00
do you get good clearence now than before I only need 2inch for me only just touching tthe bottem of the ute. We had the Jeep Jamboree in Peth last weekend I entered the the ute went very
well very happy with the Navara that is when i thought i need the lift kit
370941
Follow Up By: Leroy - Friday, Jun 10, 2005 at 11:16
Also should consider larger dia tyres to get those diffs off the ground.
LEroy
370946
Reply By: Johnny B Good - Friday, Jun 10, 2005 at 13:00
I have
got 265's 70/R16 Cooper ATR's
did have on there 255 Bridgestone HR's
115235
Reply By: Member - Toonfish - Friday, Jun 10, 2005 at 19:24
yeah i went 245/75 /16 cooper st/c this helped the diff height a bit but i wish i had the newer upper arms as they are just a tad longer (for height).
i have done some fairly substantial tracks and clearance has been as expected a little short but overcome by different techniques.
love a challenge.
lol
115279
Reply By: Russel & Mary - Saturday, Jun 11, 2005 at 09:36
Our Navara is mainly used for farm work. I made my own tray and got it galvanised. Sometimes I carry a tonne of stuff and the rear springs are very soft so I fitted a pair of those pump up polyair bellow thingos.These will alter the height about 4" or 5" on the rear end and up front I got to the torsion bar tensioners with a 19mm socket and cranked them up so the front raised and inch or two. I didn't get a wheel align and I've done 20,000 k with no visible
sign of abnormal tyre wear. When I go serious driving I slip on the 31x10.5x15 Wranglers. The pump up rear stuff cost $800 from Opposite Lock and took me an hour or so to fit. I'm very happy with it. Rus.
115337
