Electric Winch - Thomas type on 80 cruiser
Submitted: Saturday, Jun 18, 2005 at 11:12
fourbyman
This might seem strange? but will an electric winch work if under
water e.g. if stuck in river etc, purchased a 80 series with winch and supposedly only used twice on light work, what sort of servicing is required as don't have manual or instructions for it.
hope you can help!
Reply By: desert - Saturday, Jun 18, 2005 at 11:26
if you can keep the
water out of the motor then, yes it will operate underwater, but this usually proves to be short-lived or impossible for any length of time. Keep contacts servicable and clean and change the gear-box oil once a year if used at all. 90 gear oil is what it likes. Be aware that this brand of winch is very thirsty on batteries and will drain heaps of amps when worked. Short winching times and the use of a snatch block are manditory.
116238
Follow Up By: fourbyman - Monday, Jun 20, 2005 at 09:58
Thanks very much Desert, much appreciated!
371991
Reply By: Peter 2 - Saturday, Jun 18, 2005 at 20:22
Having had aThomas EW8000 for over 20 years with absolutely zero probs, they are great winch. while slower than a Warn or similar they will out pull most.
Regular servicing and oil changes as
well as greasing will keep it running.
It uses ATF in the high speed gearbox and 90 grade in the other.
I've got a copy of the owners manual somewhere too.
from memory you can dowload the manual and parts list from the website.
Here is a link to the tech page
http://www.winch.com.au/winch/winches/electWinch.html
116282
Follow Up By: fourbyman - Monday, Jun 20, 2005 at 10:00
Thanks Peter 2, really appreciate good advice from people who don't mind sharing
371992
