Rear noise in a hilux
Submitted: Sunday, Jun 19, 2005 at 23:50
burger
Just recently reset the rear springs in my 3.0dsl 98 hilux extra and raised front torsion bar up 40mm. Drives beautifully, but there seems to be a humming noise coming from rear, not a conastant noise, but has a second space in between each, when i take it up to 60k/hr. Car doesn't shake at all, its gotta a uni or a bearing(diff, wheel) but cant seem to pin point the noise anyone had any similar problems.
Reply By: Russel & Mary - Monday, Jun 20, 2005 at 08:03
Burger. Dunno mate but maybe now the height is different the aerodynamics have altered slightly and a panel is resonating from a combination of wind and normal vehicle drive chain vibration. Try putting a load in the back,say 100 kg, as see if it's still there. Rus.
116484
Follow Up By: Member - RockyOne - Monday, Jun 20, 2005 at 08:22
You did'nt mention the overall lift over standard..If the re-set was severe,the lift could require re-aliging the driveshaft/diff..Wedges are avail from
suspension places for this,to fit between rear axle and strings to tilt diff up a whisker..You can,no doubt,prove this by following Rus/Mary suggestion and loading it up,providing this does'nt just "kill" a sheet metal noise from the pickup/flat-top floor.Helps? RockyOne
371979
Reply By: burger - Monday, Jun 20, 2005 at 22:52
Thanks guys i'll give it a go.
Keep on Truckin
116630
