Cape York - WWII Wrecks
Submitted: Sunday, Jul 03, 2005 at 10:41
ThreadID: 24385 Views:4010 Replies:3 FollowUps:0
Guys,
Just doing some research for a potential trip to the Cape - does anyone have a list of WWII wrecks - hopefully already in an Ozi importable file (asking for the gravy as well now ;-)
Reply By: peterK - Sunday, Jul 03, 2005 at 10:59
Ivan
I made a bit of a blog entry here about one of the wrecks near bamaga.
blog entry
I got some of the info from
www.pacificwrecks.com
Pete
AnswerID: 118615
Reply By: The Hob - Sunday, Jul 03, 2005 at 12:07
Wrecks at Bamaga.
There is the DC3 which is on the right on the way to Bamaga airstrip from Bamaga just past the turnoff south to Cooktown.
You need to take a track which goes around the Bamaga end of the airstrip and then heads generally parallel to the strip to find the remains of a fighter? (not much there at all) and then a bit further on you will find the Bristol Bomber talked about above.
Unfortunately I don't have lat and long for them but they were fairly easy to find once you are in the right area.
AnswerID: 118621
Reply By: Bros - Tuesday, Jul 05, 2005 at 20:01
Ivan,
On the south side of the present Bamaga airfield and if you look keenly to your right while driving away from the Bamaga direction you can see the "hangers" they made out of the surrounding country to house the planes. They are u-shaped cut banks that the planes used to be wheeled into under the trees and covered with comouflage nets. This was how it was explained to me and i actually saw them.
Bros.
Work is the curse of the down and out bludger.
AnswerID: 118980
