Whats a dump pipe???????
Submitted: Sunday, Jul 03, 2005 at 21:24
babs
Hey I feel pretty dumb, I dont know what a dump pipe is. Someone on this site said they put a 3" exhaust and a dump pipe on there 4.2 T/D patrol.. What is it and what benefit power wise etc..?
Reply By: Member - John - Sunday, Jul 03, 2005 at 21:44
babs, the dump pipe is the exit from the turbo, the original nissan one necks down to about 2 1/4" and is a restriction. Putting a bigger dump pipe and bigger exhaust allows the turbo to spin up faster and breath better, making more power. Hope this helps?
118688
Follow Up By: Leroy - Sunday, Jul 03, 2005 at 22:20
What john said plus it's prob the best powerup mod you could do to a 4.2td. Mate just had a new exhaust and turbo tweaked to 10psi (he's being conservative) and the difference is amazing. Turned a wheezing slug into a very drivable vehicle.
Leroy
373870
Follow Up By: babs - Sunday, Jul 03, 2005 at 23:10
hey John do you know if this would effect my warranty?
Thanks,
Babs
373882
Reply By: Member - John - Sunday, Jul 03, 2005 at 23:19
babs, it hasn't effected my warranty, they would have to prove that it caused the problem etc.
118701
Follow Up By: babs - Sunday, Jul 03, 2005 at 23:25
John what would be the cost of changing the dump pipe and exhaust, and who would be most likely to do this mod?
373885
Reply By: Member - John - Sunday, Jul 03, 2005 at 23:38
babs, I had the exhaust done locally, about $250, MorwellVic, mates rates, the dump pipe was from ARB Northside in Brissy. I think that a lot more
places are doing them now, and cheaper. Sorry I can't be more helpful. Some one on here will have current info and will be able to help you out. Maybe try MTQ, they do them I think? They also have mods for turbo, woo hoo,
well worthwhile getting. Hope this helps?
118703
Follow Up By: babs - Sunday, Jul 03, 2005 at 23:41
Yeh it does help John, ill look into it some more thanks.
373889
Reply By: Member - John - Sunday, Jul 03, 2005 at 23:46
You're welcome.
118705
Reply By: Member - Chris M (QLD) - Monday, Jul 04, 2005 at 09:12
Babs,
Have a chat to a few guys. Whilst my EGT's dropped down a little (which is why i changed
mine over), the truck did develop a small lag at takeoff. Only reason I noticed was that I was running 12psi, with a few
fuel mods, blanked off EGR blah blah blah. Also check to see what sort of muffler you are running. You don't need a triple flow, just single. Slightly noisier but just helps if you have a 3 inch mandrel bent.
Chris.
118729
Follow Up By: babs - Monday, Jul 04, 2005 at 18:52
Hey Chris thanks for the help, but thats all to technical for me sounds like chinese. :)
373994
Reply By: JamieMac - Monday, Jul 04, 2005 at 15:34
Hi Babs
I got another post from you asking the Question in reponse to my original post 22890. Sorry but was not able to answer until now. As above it is much bigger cast elbow at outlet of turbo that removes the most restrictive bit of the exhaust. With the exhaust changed as
well it makes the car a much better beast to drive in all conditions.
A mate and I both bought same vehicle. He had his cut up and turned into a 6x4 in
Dalby so the power lag was a little more noticable. When out bush I was generally one gear higher and alot of revs lower going up inclines after doing this mod. He has now had his exhaust changed (and dump pipe) and can not believe the difference, still raving to me about it after a couple of weeks but we do like to talk about our cars!
JamieMac
118776
Follow Up By: babs - Monday, Jul 04, 2005 at 18:59
Hey JamieMac do you know what the extra power is in statistics?
373995
Reply By: Truckster (Vic) - Monday, Jul 04, 2005 at 21:23
I always thought it was something to do with the anus?
118842
Follow Up By: Lone Wolf - Monday, Jul 04, 2005 at 21:36
No Bruce....
They are a very, very real thing.
I have seen them, I think they are made by Colon Industries.....
374012
Follow Up By: Member - Jimbo (VIC) - Monday, Jul 04, 2005 at 22:55
Enough of the smart ar$ed remarks you two.
Any fool knows it's the technical term for the "U" bend at the bottom of the bowl.
374026
Follow Up By: Member - Jimbo (VIC) - Monday, Jul 04, 2005 at 22:58
Oops, I ballsed that one up, meant the "S" bend.
374027
Reply By: trendy - Monday, Jul 04, 2005 at 23:04
Babs,
Had MTQ do a stage 2 power up which involved putting a dump pipe on the back of turbo, change turbine inside turbo housing, 3" exhaust (has been done for ages), change delivery of fuel and modify timing to name a few things done, and the drive difference is amazing. Power at rear
wheels is 88 kw but the torque is what gets me,
mine is like driving an auto. It will most certainly effect your warranty should something go wrong, but as said, they would have to prove it was due to the modification. (more like you prove it wasn't from the modification) All this was done on my vehicle to stop it from overheating, 20 000 km after work has been done and things are all good, but I am waiting till summer to reach my final verdict on the overheating. If you get a 3" exhaust I would certainly recomend the dump pipe at the same time, you would have a bad dealer that stopped any warranty work being done with just the exhaust mods. It could be said you are in actual fact making the engine breath easier with these mods therefore less stress to engine.
I had similar power up done by S@f@ri, when the car was new, but they could not fix overheating with their setup so 3 grand down the tubes. Learn from my mistake and use MTQ if you go the whole hog.
Regards Trevor.
118871
