Engle Fridge
Submitted: Saturday, Jul 23, 2005 at 21:09
Ray Bates
Hi all you lovely lads. I'm after a bit of advise????? I have an Engle fridge that only operates on 240 volts. Any suggestions??????
Reply By: hoyks - Saturday, Jul 23, 2005 at 21:33
Have you:
Tried changing the polarity of the 12V plug?
Re-set the circuit breaker?
Checked the fuse in the end of the 12V plug?
Checked that there is actually 12V coming through the plug?
Other than that I don't know.
121781
Follow Up By: wylie - Saturday, Jul 23, 2005 at 23:49
mine did this ,it turned out being a fuse - special engel one that looked alright but when replaced made all the difference .
i think it cost 12.00 bucks a couple of months ago
go
mine tested at a place in wangara (WA)
376961
Reply By: geocacher (djcache) - Saturday, Jul 23, 2005 at 23:50
Low voltage will do this.
Does the green light come on but the fridge not start up?
I had a similar problem and found that oxidisation in the fuse holder was the problem. Pulling the plug from the base of the fridge and measureing with a multi meter it looked like the fridge was getting 12 volts, but when I plugged it in and measured under load while the fridge was trying to start up the voltage was about 8 volts.
Went back over the leads and connections and found some
water had found it's way into a semi sealed blade fuse holder and the contacts were a bit dull and grey looking instead of shiny. Pulled fuse and cleaned and replaced it and presto. Fridge worked.
Changed fuse holder under bonnet since.
Dave
121789
Follow Up By: Ray Bates - Sunday, Jul 24, 2005 at 10:08
Hi I have one of the old green engles. It does not have any lights on it
376975
Reply By: Ray Bates - Sunday, Jul 24, 2005 at 20:21
Hi Guys. Fixed the problem with the Engle. Broken wire
121842
