Spare wheel carriers
Submitted: Sunday, Jul 31, 2005 at 17:28
Steve
are these things easy to take of/put back on? I'd like one for going away but would like to take it off in between trips so I can get my car back in the garage.
Reply By: Member - Nick (TAS) - Sunday, Jul 31, 2005 at 17:34
Gday Steve,I guess you could do it two ways.You could take the carrier off at the bearing swivel ass. be a bit messy(grease) and you would be left with the swivel stub sticking up.The other way would be to take the wheel off the carrier,it would stick out a bit further but alot easier.
123020
Reply By: Crackles - Sunday, Jul 31, 2005 at 19:47
A 5 minute job. Remove a split pin, undo the castle nut, then lever the arm with the bearings off. I made up a piece of pipe with a nut welded inside to screw over the greasy stub axle.
Cheers Craig...........
123043
Reply By: wheeler - Monday, Aug 01, 2005 at 09:29
I have a Kaymar rear wheel carrier fittied to my 100 and it is a simple matter of fremoving the dust cover. Removing the split pin and undoing the castle nut. I also have a pivot cover which sits over the top of the pivot.
123106
