aliner suspension
Submitted: Monday, Aug 01, 2005 at 10:16
ThreadID: 25239 Views:3217 Replies:1 FollowUps:1
I was looking at an Avan Aliner and noticed that the axle was only attached by two bolts on each side of the sub frame. It looked a bit flimsy for a torsion suspension system. There were extra holes drilled in the mounting plate which would allow for 2 more bolts into the subframe but these were not fitted.
I wonder if the two extra bolts are usually fitted and were forgotten in this case, or if the mounting that I saw was standard.
If so how good is it?
Reply By: Bob&Deb - Tuesday, Aug 02, 2005 at 07:11
G`day billy. Ithink the suspension you are talking about is an AL-KO, we fit hese to camper trailers. They are pretty close to bullet proof, we have had only one that developed trouble. With that one we were told GVM loaded would be 1700kg, in reality the bloke was grossing 3000kg. Yes thy are secured by only two bolts each side, but we also fit stop lugs front and rear of the mounting plate.
Keep wandering
Regards Bob
AnswerID: 123273
Follow Up By: billy bushrat - Wednesday, Aug 03, 2005 at 08:35
Thanks Bob, I'll put the head under and have another look for stop lugs.
Billy
FollowupID: 378523
