Why am I being thrown off Forum?
Submitted: Tuesday, Dec 03, 2002 at 01:00
ThreadID: 2524 Views:2219 Replies:4 FollowUps:3
Hi all.
I have a question as this has happened to me a couple of times now.
I log in to read the posts or to respond to a question. At times I am presented with the login screen again when I want to make a reply, as was the case today.
I log on and then type my whatever. I click on the Submit Reply button and I am again presented with the page saying that I must log on to participate, no problem except all my typed material IS GONE! As was the case today.
Is it something to do with my under-arm deodorant? ;-)
Reply By: Member - Nigel - Tuesday, Dec 03, 2002 at 01:00
Maybe your cookies are burnt.
AnswerID: 9291
Follow Up By: Tuco69 - Tuesday, Dec 03, 2002 at 01:00
Yup - sounds like a cookie problem to me also.
FollowupID: 4656
Reply By: ExplorOz Team - David - Tuesday, Dec 03, 2002 at 01:00
Janset,
it actually sounds to me like you are not using AutoLogon and we have had a system problem. We have been experiencing an unusal amount of system reboots over the last few days (we are of course looking into this). If you do not have Auto logon set then the system will prompt you to login when your session has expired or if the system is rebooted during your session. This could be causing the issue you have identified. Do you have Auto Logon enabled? If not might I suggest that you logoff and then o to the logon screen and enable AutoLogon.
David
AnswerID: 9294
Follow Up By: Janset - Wednesday, Dec 04, 2002 at 01:00
Hi David.
I think you have answered my question and I will enable auto logon as you suggest.
FollowupID: 4678
Reply By: Will - Wednesday, Dec 04, 2002 at 01:00
I get the same problem....
What is the timeout for the system before it logs me out?
Will
AnswerID: 9306
Follow Up By: Exploroz Team - David - Wednesday, Dec 04, 2002 at 01:00
Will,
The default session timeout occurs after 20 mins of inactivity. That is if you do not change pages or hit a link for 20 mins your session will time out. There is now reason not to enable autologon, this was designed to fix this problem.
David
FollowupID: 4679
Reply By: steve - Wednesday, Dec 04, 2002 at 01:00
do you have your privacy settings set to high and stopping the cookies i reset mine and had alsorts of trouble .I reset to about half way and it seems fine again now
steve
AnswerID: 9326
