water leak
Submitted: Monday, Aug 01, 2005 at 13:25
ThreadID: 25250 Views:2774 Replies:10 FollowUps:3
hi all seem to have a water leak,in my landcruiser inside driver side bottom right side kick pannel, notice the carpet a bit wet so thought to have a look,well leak alright all my carpet was wet underneath,dried it with hair dryer,a cant find where the water is coming from had my son ran the hose on the bonnet and down the windscreen while having a look cant see how its getting through has anyone the same problem help please regards stan
Reply By: BenSpoon - Monday, Aug 01, 2005 at 14:12
Done any water crossings or splashing through any puddles lately?
Checked the rubber grommets on the firewall are sealing?
was it on the flat floorpan section or behind the pedals?
AnswerID: 123144
Reply By: stans truck - Monday, Aug 01, 2005 at 14:37
hi there ben ok no water crossing just washed it and noitice the floor near the kick pannel was wet far right hant side take the kick pannel of and all my wiring was wet and the gutter where the wires are laying was full of water not good all rubber seals are in p,lace on the floor pan seem to be ok ,but the water is coming through the top right han side seem to be through the fire wall maybe dont know cant see
AnswerID: 123149
Follow Up By: BenSpoon - Monday, Aug 01, 2005 at 16:55
The easiest place to check the condition of the grommets is on the engine bay side. Keep an eye out for ones with multiple holes in them. They often work loose esp if someone has run new wire through it recently.
There was also mention the other day in a thread of rear window squirter feeds being run down the sides of cars- can you identify all the cables in that channel as electrical? does the rear squirter have the same pressure as it used to?
Also check the underside of your doors- Mine has little slots for letting water drain out that clogged up with mud and water was sloshing around in the door. There is stuff on lcool.org about water in the sills, but as I understand it that is external to the cabin.
FollowupID: 378249
Reply By: Skinny- Monday, Aug 01, 2005 at 14:39
I found in my 80 series that when I fitted the speakers in the doors I ripped some the waterproofing inside the door. When it rained it came in through the door and dripped off the speakers. Refitted the plastic and bought two weather shields, one of those things fixed it.
Skinny
AnswerID: 123150
Reply By: Member - George (WA) - Monday, Aug 01, 2005 at 15:59
Have you had a new winscreen fitted. I had the same problem after my windscreen was replaced. Went back and they resealed the windscreen. Problem solved. 80 series L/C
AnswerID: 123161
Follow Up By: Member -Dodger - Monday, Aug 01, 2005 at 17:06
Yep that's my guess as well windscreen probs or the air con water disperser has been torn.
Cheers Dodg.
FollowupID: 378252
Follow Up By: Member - George (WA) - Monday, Aug 01, 2005 at 18:31
Air con water disperser is on the passenger side. I have had that problem also with the discharge hose comming away.
FollowupID: 378270
Reply By: fourplayfull - Monday, Aug 01, 2005 at 18:35
May pay to check same leaks I had on my 80 - windscreen top rubber seal leaked only if vehicle parked facing slightly downhill as water then ran under seal and only evident on floor carpet - remedy , new seal or" raise front susp. only" .
The steering firewall rubber seal was destroyed at 220,000 kms so another bad leak - easy to check firewall gaps etc. - place work light under bonnet at night & check under dash for tell tale holes .
CYA John
AnswerID: 123186
Reply By: stans truck - Monday, Aug 01, 2005 at 21:11
thanks to all will try all the above and see what happens thanks stan
AnswerID: 123232
Reply By: muzzgit (WA) - Tuesday, Aug 02, 2005 at 00:25
Stan, you havn't stated what model cruiser but I had a 60 series which leaked in the front, wasn't the windscreen! wasn't the heater! turned out to be from under the bonnet where a rubber seal running the width of the bonnet is clipped in with plastic clips. the clips break off and water gets in thru the holes.
AnswerID: 123262
Reply By: Horacehighroller - Tuesday, Aug 02, 2005 at 00:26
Does the vehicle have a sunroof?
Peter L
AnswerID: 123263
Reply By: stans truck - Tuesday, Aug 02, 2005 at 12:53
muzzgit no it dose not have a sun roof my crusier 1999 modle 100 series petrol lpg.
AnswerID: 123332
Reply By: stans truck - Thursday, Aug 04, 2005 at 14:59
well guys if your intreasted problem fixed went to a windscreen mod and sure enough right side was the problem took the strip of wich runs up the side of the winscreen bingo 4inch gap water was running down the inside pillar and down to the floor boged it up and now ok and did it for free good service hey.
AnswerID: 123802
