servicing the 2.8 diesel turbo
Submitted: Tuesday, Aug 02, 2005 at 10:55
blackwrx
I am after some quick info if possible.
I want to service the patrol I have just brought and would like to know the filter numbers etc that I require.
eg: oil, petrol and air filter numbers?
I would also like to know what type of oil to put in the engine and how much it requires?
Someone also said that I should put in a tube o0f stop smoke aswell as some injector cleaner.
This should help clear up any smoke issues etc.
Reply By: 3.0turbob - Tuesday, Aug 02, 2005 at 12:05
If your Patrol has a vehicle hand book, it will tell you the type of fluids as
well as their specification. As for the filtert part numbers, just ring your local (or any) Nissan spares dept. and they will tell you. You just need to supply them with the vehicle VIN number (in the engine bay at the rear on the firewall will be a plate with this info)
123319
Reply By: Member - Bigbear - Tuesday, Aug 02, 2005 at 12:12
This is what I use
Oil- Castrol GTX Diesel Oil 15w/40 6.4 litres with filter
Filter - Ryco Z419
Fuel filter
I have Racor adaptor with glass bowl and use Racor R26T filter
Air filter iether Ryco HDA5809 or Finer Filter FF4392 I use both depends on what I am doing.
Hope this is of some help
123322
Reply By: Member - Foxer - Tuesday, Aug 02, 2005 at 21:54
Go to your local Auto
shop, Auto Pro, Repco they will have them all
123460
Reply By: rolande- Wednesday, Aug 03, 2005 at 11:50
G'Day.
I use genuine oil and
fuel filters, $36 for oil, $28 for
fuel.
Oil itself is
Caltex Delo CXJ. This is supposed to be as close to the Japanese spec oil on the market as you can get, has a label on the drum, "for high speed japanese diesel engines". $100 for 20ltrs
Remember that 5,000k changes will do a lot of favours for the 2.8
Rolande
123541
