Help!!! OME Steering Damper
Submitted: Tuesday, Aug 02, 2005 at 14:59
ThreadID: 25284 Views:2769 Replies:4 FollowUps:0
Just installed a new OME steering damper today, and when tightening nut the outside washers on both ends, are not pulling down square on the bushes. The kit damper came with no instructions for fittment so I am presuming that the side of the bush with the raised centre sits facing the mount hole brackets? Is this normal?
Thanks Dicko1980
Reply By: dicko1980 - Tuesday, Aug 02, 2005 at 15:12
Forgot to write that the vehicle is a GQ Coilcab ute.
AnswerID: 123360
Reply By: Member - Roachie (SA) - Tuesday, Aug 02, 2005 at 16:54
I reckon the raised area of the washers should be on the side of the nut (ie: away from the bush). Sort of like this......([])......
Roachie
AnswerID: 123375
Reply By: dicko1980 - Tuesday, Aug 02, 2005 at 17:03
The washers are straight forward to install, its the bushes that are a little bit questionable. The bushes are the same at standard nut have a raised nipple around the centre on one side. This nipple fits neatly in the hole that the damper locates in on the car.
Regards Dicko1980
AnswerID: 123377
Reply By: Hero - Wednesday, Aug 03, 2005 at 08:58
Why dont you ask OME?
AnswerID: 123510
