IPAQ lost Programs?????????
Submitted: Friday, Aug 05, 2005 at 09:16
Member - Crazie (VIC)
Thank god its friday.
Anyway hi all, I went and grabbed my IPAQ last night out of the Jack, as i recently got wireless broadband at home, what a drama that was, another story.., anyway was going to configure it, the IPAQ, on my wireless Broadband, but i turn it on and it starts the whole setup screen and once its on, i have lost my programs i have installed (Destinator and Oziexplorer). Quich check and everything on the storage card is still there, phew.. Its is only a few months old, sits in a powered cradle in the Jack. I have heard of these things loosing things when the battery goes flat, have my set to turn off in 3 mins if not being used
Anyone got any ideas why i lost things......
Not having fun with computers latley
Reply By: Member - Sam (NSW) - Friday, Aug 05, 2005 at 11:15
It hasn't gone and created a new profile? Ie modified the original so that all your original settings are then when it's docked or on wireless and then when its un-docked, created a new profile, that isn't showing the installed applications? I haven't played with PDA's too much, but this is something that came to mind.
123943
Reply By: Vince NSW - Friday, Aug 05, 2005 at 17:28
Hi Crazie,
If you find the answer let me know. We use the &*@ things as data loggers for work. I allways make sure that they are working from pgms on the card and all data is saved to the card.
I don't know how many times we have turned them on , only to get the set up screen. It's now second nature to just look for the data on the sd card.
Not much help I know, But.
Vince
123991
Follow Up By: Member - Crazie (VIC) - Friday, Aug 05, 2005 at 18:32
Hi Vince
Thanks for the similar story hahaha, first time it has ever happened. Have all the maps on the SD card, so all good
378959
Reply By: Member - Stan (VIC) - Friday, Aug 05, 2005 at 18:09
Adam,
One thing to check is that if you are running Oziexplorer, it's got
a "Keep Alive" setting which emulates the user input every few
seconds, so that the Pocket PC won't got to sleep...
If you got this feature turned on (my pocket PC does) then
this could be the reason your battery got flat... Although my IPAQ
is smart enough to switch off anyway before everything is lost...
Stan
123993
Follow Up By: Member - Crazie (VIC) - Friday, Aug 05, 2005 at 18:33
Hi Stan
Yes my IPAQ is hard wired in the 4WD, and yes it turns itself off when not in use and also has a backup battery. This thing cost $1300, think it is smart enough, that is why i am a little lost... lol
378961
Follow Up By: Moggs - Friday, Aug 05, 2005 at 18:49
I have been caught out this way a few times - I un-check all the power saving settings (this is manual in the Axim) so that it doesn't dim when using Ozi and then forget to put them back on.
Adam,
Have you tried a soft reset to see if you can just re-boot it? Very strange that just installing / setting up a profile would ditch other programs. Good luck with it.
.... and where are the piccies from the snow trip???
378963
Follow Up By: Moggs - Friday, Aug 05, 2005 at 18:51
sorry...also meant to add - I have only lost everything off my Axim once - accidently did a hard reset while mucking around with it - was a struggle to remember how I had OziCE set up but got it back on ok. Like you - had all the maps and CE track files on the 1 gig SD card.
378964
Follow Up By: pjchris - Saturday, Aug 06, 2005 at 22:42
The iPaq 4700 actually doesn't have a backup battery per se.... It is a very small rechargeable and I find that if you remove the main battery (or it goes flat) the backup battery can maintain the contents of the iPaq for about 5-10 minutes. It is really only there so you can change the main battery without losing everything.
379078
Reply By: Member - Scrubba (NSW) - Friday, Aug 05, 2005 at 20:36
Crazie,
When you install programs, they install to memory (or RAM) by default. When the IPAQ loses power, memory is cleared. Sometimes the IPAQ will do a 'hard' boot (or 'cold' start if you prefer) for unexplained reasons. This too will cause loss of programs stored in memory.
RAM requires a constant power supply to prevent data loss.
The trick is to not accept the default RAM location for the install. Change it to be the 'file store' or one of the storage cards. These are non-volatile storage options.
Hope this helps!
regards,
Scrubba
124009
Follow Up By: Member - Crazie (VIC) - Friday, Aug 05, 2005 at 23:43
Hi Scrubba
Will the programs work fine if I install them on the SD card??
Thanks for the info
ads
379000
Follow Up By: Member - Scrubba (NSW) - Saturday, Aug 06, 2005 at 20:27
I guess Dave answered that for you below.
Mine is installed on the IPAQ's FileStore with maps and data located on the SD card. Didn't have sound prompts till I moved all the OziExplorer wave files into the data directory on the SD card as
well. Took a little while to work out.
Rgds,
379051
Reply By: prado_95 - Saturday, Aug 06, 2005 at 15:31
Unfortunately the earier devices did this for no explainable reason.
Ozi has some issues for installed direct to the storage card (but seems Ok if you move it over after install and adjust the appropriate parameters).
I keep IPAQ (& GPS) constantly powered. This eliminates the 'missing program' issue that would otherwise occur if the power is off for a few weeks.
One of our customers also had the same issue for the application we wrote for them when people come pack from a few weeks holiday.
The simple answer is to keep it powered up, and switched off when not in use.
Dave
124078
Follow Up By: Member - Crazie (VIC) - Saturday, Aug 06, 2005 at 15:57
Hi Dave
Yep, it sits in a powered cradle and hardly ever comes out. It is only 2 months old, It has a back up battery and a automatic turn off, I am just figuring i must have left it on, on one of the very few times i take it out lol.... haha always they way.
thanks
Ads
379033
Reply By: Member - Smocky (NSW) - Monday, Aug 15, 2005 at 22:08
G'day Ads,
these things are notorious for that. Don't beat yourself up for an answer, it went flat. Simple as that. I used to use an iPaq 3630 that would do it if I didn't cradle it daily. Now use an iMate that is better with battery management, but still had to totally re-install a few times.
New version of Windows PocketPC 2005 is supposed to support better memory management and storage. That doesn't help you but :)
Just do your best to keep it powered.
Jason.
125336
Follow Up By: Member - Crazie (VIC) - Monday, Aug 15, 2005 at 22:36
thanks mate
I must have left it on, on my desk one day, bugger it, I have loaded it all again now, being very careful when i take it out of the 4wd.
Hope all those things worked ok.
ads
380092
Reply By: Richard Kovac - Saturday, Aug 20, 2005 at 19:02
Crazie
I have a HP 2110 iPAQ, it came with a backup program on it called iPAQ Backup from sprite Software www.spritesoftware.com
I have it set to back up each day onto a cf card.
I,v had to use it twice to restore all added programs and files
it also will backup to the ActiveSync on the laptop
so fare it has worked fine
Richard
iPAQ Backup
126051
