mazda tribute wheels and tyres
Submitted: Saturday, Aug 06, 2005 at 08:38
ThreadID: 25391 Views:8954 Replies:5 FollowUps:2
G'day everyone.
I have a tribute limited which from new was fitted with 16x7" alloy rims and
215/70/R16 tyres. I wanted alloy wheels at the time of purchase, however the
car came with 16x6.5" steel rims and 215/70/R16's.
The dealer said we could have a genuine mazda alloy rim and he showed us a
picture of it and we said ok.
What I have found out is that the 215 tyres were taken off the 16x6.5" rims
and fitted to the 16x7" alloy rims and that is what we got when we picked the car up.
I have looked at mazda specs for the various tribute models and they say
the 16x7" alloy rims fitted on the more luxury model than ours have the
235/70/R16 tyres.
We need new tyres and I would like to fit the better looking 235/70/R16's
our 16x7" alloy rims, but mazda say I can't as our tribute limited is set up
differently than the luxury model.
They say the steering rack is different and there may be car body fouling if I fit the
slightly larger tyre.
What to you people think?
Reply By: herkman - Saturday, Aug 06, 2005 at 10:03
As an old Triibute owner, I think the dealer has taken the cheap way, just like Mazda has done with your spare, which is really a Gloryfied run flat, totally useless.
We bought the top of the range, and the dealer claimed that full sized 235 spare would not fit in the tray.. We insisted he supply the correct spare and just load it on delivery in the cargo area. Needless to say the full size spare with minor mods would travel in the boot.
Now to your problem, I have a Tribute parts CD, and it shows no changes in any of the areas that you have mentioned. Also if you study the Escape, same car really and in RHD come out of the same factory, they too have the same parts.
The Tribute Limited, has a brother that was introduced for marketing purposes, it was called the sport, it too came the distributor with mags on, but even though they were Mazda mags, they did not have the same spoke profile. I believe Mazda bought these in bulk and fitted them here.
I suggest that you get your tyre dealer, to fit one tyre to the front and whilst it is on the hoist, check the clearances. I can see no reason for them to foul. Or you could ask the Maxda dealer to show in the parts CD, where the parts are different, because I cannot find any changes.
I suspect the dealer has done the tyre change on the cheap, if you check your spare you will find that whilst it may be 215, the tread pattern is low, and it should be marked, speed linited to 80 KMPH.
Col Tigwell
AnswerID: 124056
Reply By: domino - Saturday, Aug 06, 2005 at 11:47
Thanks Col
I thought they had did something shifty.
I will take on your suggestion and speak to a tyre retailer.
I smell a rat when I speak with the mazda people.
Tell me how to obtain a tribute parts CD.
AnswerID: 124063
Follow Up By: bluey70 - Saturday, Aug 06, 2005 at 12:07
domino
there a 2 different steer racks for the mazda tribute with or without the factory flares.
FollowupID: 379023
Reply By: herkman - Saturday, Aug 06, 2005 at 18:50
My CD has already gone to a good home.
If you find a friendly parts man at a Mazda dealership, that is the only way you will get one.
Ask him when he gets a new issue, if you can have his old one.
Beware use a Ford dealer as a source of parts, only in an emergency. There prices are out of this world. Mazda oil filters for example are only 40% of the price of the ford ones. Also the Mazda filter removal tool, does not fit the motorcraft one off the excape.
DO NOT UNDER ANY CIRCUMSTANCES, use a auto transmission fluid which is better quality than standard. We used synthetic oil in ours from new, with both the blessing of Mazda and the dealer.
At 24,000 kms both clutch packs failed, and luckly Maxda remembered the inquirey and changed out the transmission under warranty.
The Tribute has a FORD CD4 transmission in them, and my source in the USA, states that they are only just a transmission.
Col Tigwell
AnswerID: 124109
Follow Up By: Exploder - Saturday, Aug 06, 2005 at 21:34
What type of ATF did you put in, as this can be a killer of automatic transmissions put the wrong fluid in and you can destroy them (As happened with yours). If it was a ford transmission then it would most likely required a ford “Mecron” Type Fluid not a Dextron.
As far as I Know the only company that makes Synthetic ATF that meats ford standard is Penrite and it's $100 for 8Ltrs
FollowupID: 379065
Reply By: herkman - Saturday, Aug 06, 2005 at 22:47
The Dealer put the product in after consultation with Mazda. I do not know whose and what it was.
I was told by a contact I made with Ford USA, that the CD4 transmission is not to use synthetic oil at all.
The dealer claimed he did not know that it was a Ford transmission.
I would not have purchased the car, if I had been told of this situation.
Whole situation left a bad tast in my mouth.
Col
AnswerID: 124134
Reply By: Member - Tonester (VIC) - Monday, Aug 08, 2005 at 11:03
Hi Domino. What does the tyre placard say? By my calcs there's 4% increase in diameter going to the 235s (and a 28mm increase, over the 15mm limit depending what state). Might have to recalibrate your speedo perhaps too.
AnswerID: 124255
