Petrol engijne out Diesel engine in??
Submitted: Thursday, Aug 11, 2005 at 09:42
Fishn
Just wondering if anybody knows if it is possible to fit a 2.5 Diesel engine into an 86 SWB pajero that was originally a 2.6 petrol??
Cheers Chris
Reply By: flappa - Thursday, Aug 11, 2005 at 11:11
Yes its possible , but wonder why you would.
The cost involved in doing so , would FAR outway the value of the vehicle.
Overcapitalisation springs to mind.
124755
Follow Up By: Fishn - Thursday, Aug 11, 2005 at 11:21
the motor i can get cheap, but having thought about it id most likely have to change diffs and do a whole lot of other crap, that im far to lazy to do
cheers anyhow
379631
Follow Up By: Member - Jeff M (WA) - Thursday, Aug 11, 2005 at 13:19
"Overcapitalisation springs to mind. "
"That's a big arial." (the castle) LOL.
379644
Follow Up By: Member - Paul J (ACT) - Thursday, Aug 11, 2005 at 13:35
Nothing like the smell of diesel "Flat Out" (castle, but altered)
379649
Follow Up By: Member - Jeff M (WA) - Thursday, Aug 11, 2005 at 13:55
"Aaaaah the serenity..."
"The Dogs love it up here" (tied to a tree with about 2 inches of leash).
There are SO many!! It's a CLASSIC!
"Just paid for itself!"
"Tell'em he's dreeeeaaamming".
"Darrel dug a hole" "and it's filling with
water!"
379655
Follow Up By: Member - Paul J (ACT) - Thursday, Aug 11, 2005 at 14:02
See that?
What?
Back there....
"That's going straight to
the pool room".....
Beef
Wellington, its meat wrapped in pastry.....
379658
Follow Up By: Exploder - Thursday, Aug 11, 2005 at 20:00
Nothing to dangerous. What do you know about Lead?
1 more thing, Put the gates around the back.
379699
Reply By: Member - Matt Mu (Perth-WA) - Thursday, Aug 11, 2005 at 11:42
Yes there would be sooo many little things to change, that you wouldnt even think about till you get to it. Might even need to run an extra
fuel line depending if the 2.6 had a return line! Exhaust, electrics (glow etc) , throttle cabling, bellhousing?, air cleaner?, dash (tacho)?
Might be easier to start with a half cut and then sell the leftovers after the swap if you were determined!
Matt.
124756
Reply By: goog - Thursday, Aug 11, 2005 at 16:47
not worth it have to change diffs and gearbox better off bying new car 2.5 diesel to gut less better off getting 3.0L turbo or 2.8L turbo most 4x4 are the same only the engines are diffrent
goog hope i could help
124792
Reply By: theshadows - Thursday, Aug 11, 2005 at 19:49
sell the car buy a new one.
you will need
a
fuel cap
inlet
fuel pipe
all the flexible feul lines changed.
new filters
different diffs
different inlet shaft ...or exchange gear box.
different flywheel and clutch.
new eletrics
alternator will need need a vacuum pump put on it.
power steering pump will need to be changed for the lower idle speed.
new engine mounts
different radiator.
you can manually put a kill cable on the motor and pop a mercedes starter, glow ,kill cable on the dash that will save a lot of hassle and money
honestly just buy a new car it will only cost you $ 4 grand to import one in from japan landed.
shadow
124830
Reply By: Fishn - Thursday, Aug 11, 2005 at 20:57
Ok so it seems nothing but a pain in the arse to put a diesel in, i only wanted it for more torque on uphill work, so now im getting to thinking how about i put a v6 in it?? anyone done this or know of reasons why this is a bad idea??
124849
Follow Up By: goog - Friday, Aug 12, 2005 at 17:56
would be a much better idea but still some cost involved
goog
379792
