diesel 2.8 help with compression
Submitted: Sunday, Aug 14, 2005 at 09:57
ThreadID: 25581 Views:2018 Replies:3 FollowUps:1
Hi all can anyone tell me about the compression in a 2.8 diesel I have just purchased a reco and it has so much compression the starter has trouble turning it over have they got a decompression valve or could it be something blocking the exhaust valve.
Reply By: Martyn (WA) - Sunday, Aug 14, 2005 at 12:10
Luggy,
Be wary could be more than compression. Take all the glow plugs or the injectors out and try to turn the engine again to make sure it isn't something else that is tight. If it's a reco and hasn't run could be valve timing or a multitude of other things. Hard to diagnose over the net.
Keep the shiny side up
AnswerID: 125096
Reply By: luggy - Sunday, Aug 14, 2005 at 18:21
Thanks Martyn, I did try taking the glow plugs out and it turned over O.K without any resistance and plenty of air came out the plug holes but once back in, it became very hard to turn over,checked the timing on the front, everything is in line could it have anything to do with the injectors, injector pump timing is O.K (checked)
AnswerID: 125124
Reply By: Boc1971 - Sunday, Aug 14, 2005 at 19:03
any chance you can get hold of a compression tester ? - is it also possible that the starter motor is getting lazy ? perhaps battery also ? maybe even main electrical leads to battery ? a continuety test will not show a break down in leads - do you have an amp meter ? sorry for all the questions , often the problem is not what you would first think
Frank
AnswerID: 125135
Follow Up By: luggy - Monday, Aug 15, 2005 at 21:11
thanks for the advise frank found the problem it was the main earth lead conection to the engine ( engine did not have a very good earth contact witch resulted in starter motor not working at it's full potential)
thanks luggy
FollowupID: 380076
