flushing oil
Submitted: Sunday, Aug 14, 2005 at 10:19
ThreadID: 25582 Views:2787 Replies:3 FollowUps:3
gid'ay all
when changing engine oil brand is it advisable to run a flushing oil thru first
what do youse' reckon.
regards toohey
(castrol magnatec to what ever)
Reply By: Martyn (WA) - Sunday, Aug 14, 2005 at 11:57
Toohey,
In my opinion so long as you change the filter at the same time, plus drain the oil when it's hot you can't do much better. If you use a flushing oil you are only going to contaminate your new oil with a residual amount of flushing oil. Personally I don't like the fushing oils they can disturb deposits that can circulate doing more harm than good. After the first change the old oil will be well and truly diluted anyway. My opinions a usual.
Keep the shiny side up
AnswerID: 125095
Reply By: Max - Sydney - Sunday, Aug 14, 2005 at 19:04
Waste of money - just chnage the filter!
Max
AnswerID: 125136
Reply By: Member - Chrispy (NSW) - Sunday, Aug 14, 2005 at 19:20
Don't worry about swapping brands of oil and flushing in between - but I'd swap the filter as a matter of strict habit. You can even swap between dinosaur and synthetic oils without worrying about a flush. What the heck... you can even mix them!
AnswerID: 125142
Follow Up By: Member - toohey - Sunday, Aug 14, 2005 at 19:59
thanks fella's
change oil&filter every 5k
cheers toohey.
FollowupID: 379909
Follow Up By: Member Eric - Sunday, Aug 14, 2005 at 20:34
""""""You can even swap between dinosaur and synthetic oils without worrying about a flush. What the heck... you can even mix them!"""""
Sorry but this is the kind of advice that cloggs oil galeries and causes cattastrofic resaults , You can NOT mix oils .
Mixing oils is just as bad as not changing oils, All oils are made to spec. I wont bother going into detail , it would take a ten page email to explain it all
FollowupID: 379913
Follow Up By: Member - Chrispy (NSW) - Sunday, Aug 14, 2005 at 20:45
Generally I wouldn't do it Eric - agreed.
I should have better explained myself. After draining the engine from one particular brand of oil, or between swapping from mineral to synthetic - a small amount will obviously stay behind - in some lower oil galleries in the main. When you've drained the best you can there will some of the old stuff left behind when you go to fill up with the new oil. At this point you have a slight mixture. This shouldn't be of too much concern.
I certainly wouldn't go mixing 50:50 or anything!!!!
FollowupID: 379917
