GU Patrol 4.2td Front Hub Problem in 4WD
Submitted: Saturday, Aug 20, 2005 at 22:33
mangopickel
When driving in soft sand with tyres fully inflated in 2nd gear under pressure, the front wheel slips (seems to be mainly drivers' side) and locks with a clunk noise. We have just spent a considerable amount of money fixing the front diff thinking this was the cause but the problem still exsists. Yes, the hubs are locked in correctly. Any other ideas???
Reply By: muzzgit (WA) - Sunday, Aug 21, 2005 at 00:27
Take it back.
126096
Reply By: 120scruiser - Sunday, Aug 21, 2005 at 07:58
Are they auto locking hubs or manual ones?
There is obviously a sticky mechanism inside one hub.
Maybe need to be pulled apart, cleaned and greased.
126106
Reply By: Tuff60 - Sunday, Aug 21, 2005 at 10:19
Can't think how the nissan locking hubs work without looking at one again, that said Toyota's hubs are known for playing up when the wheel bearings are getting tired. So have you checked the bearings??
126125
Reply By: Michael_FNQ - Sunday, Aug 21, 2005 at 18:21
I also have a Nissan GU Ute and found up at
Cape York that the front manual hubs unlocked themselves whilst driving along. They unlocked in both sand driving and on dirt roads, spoke to Nissan, they acknowledged the problem but offered no fix!
126179
Reply By: Diamond (Vic) - Sunday, Aug 21, 2005 at 19:40
first thing that strikes me is why are you driving on sand with tyres fully inflated.
try doing it with the tyres at proper presure for sand(usually less than 20 psi) and see if the problem persisits.
126203
Follow Up By: Member - Roachie (SA) - Sunday, Aug 21, 2005 at 21:28
That's right Diamond.....get the pressures down to start with. If there is "slipping" it could be due to the lack of a cross axle locker. One wheel could be scrabbling for traction and slipping as a result. Then, when It gains a foothold on a patch of sand etc, it could be clunking into action.
380869
Reply By: Leroy - Sunday, Aug 21, 2005 at 21:38
Does the front wheel just loose traction? If the left wheel looses traction, all power to the front is transferred to this wheel. This possibly could be attributed to tyre pressures. But this doesn't explain the clunk noise.
Leroy
126228
Reply By: ACDC - Sunday, Aug 21, 2005 at 22:19
Auto hubs are a common fault if they are playing up replace them with AVM hubs for about $200.00
126233
Follow Up By: Patrol22 (Queanbeyan - Monday, Aug 22, 2005 at 12:51
Yep agree totally. I've just tossed my auto hubs in favour of a set of AVM manual hubs -$170 and half hour to fit at home.
380918
Yep agree totally. I've just tossed my auto hubs in favour of a set of AVM manual hubs -$170 and half hour to fit.
380919
Follow Up By: Member - Roachie (SA) - Monday, Aug 22, 2005 at 14:06
Yep; me too......manual hubs are so much more verstile (you get to choose whether they are engaged or not; so you can use low range without being in 4wd if you ever need to.....eg: pushing a heavy trailer up a concrete driveway etc)
380928
Reply By: Martyn (WA) - Sunday, Aug 21, 2005 at 22:26
Mangopickle,
You say the hubs are locked in correctly, is the arrow in the auto setting or the lock position? If the hub is in the auto position and you are switching between forward and reverse there will be a certain amount of free movement between backward and forward motion, if there is power on this will be a nasty clunk and quite a shudder. If you are driving in sand it's better to have the hubs in lock, if you are aware of all this sorry. Accelerating and decellerating in auto lock can be quite frightening especially on gravel and up and down hills. My opinions and experiences etc etc
126235
