Lokka Lockers
Submitted: Wednesday, Aug 24, 2005 at 07:39
ThreadID: 25835 Views:2308 Replies:7 FollowUps:4
Are these lokka's meant to make crunching noise whilst the hubs are not even locked??... and not in 4wd???...
when turning???? slowly???
Reply By: Well 55 - Wednesday, Aug 24, 2005 at 08:32
If the hubs are not looked and it's not in 4WD, nothing in the front diff should be turning.
So I guess no.
AnswerID: 126572
Follow Up By: Member - Roachie (SA) - Wednesday, Aug 24, 2005 at 08:40
Spot on ....... If hubs are not locked and stubby lever is fully forward, everything in the front axle tube and pumpkin is having a total sleep. So the crunching noise must be something else.
Sounds nasty..... :-(
Good luck
Roachie
FollowupID: 381150
Follow Up By: Bonz (Vic) - Wednesday, Aug 24, 2005 at 20:43
definitely no, unless they havent auto unlocked like in a Patrol/Pajero
FollowupID: 381258
Reply By: Well 55 - Wednesday, Aug 24, 2005 at 08:48
After hearing the noise that broken CV's make on the weekend. Could that be it?
AnswerID: 126578
Reply By: Ando80 - Wednesday, Aug 24, 2005 at 08:56
I second that!, Check the CV's, especially if it's worse at full lock.. but if your hubs are automatic, maybe there is a problem there and they haven't disengaged??? From memory the Nissans have an option of auto lock or manual lock, this is also something that may need checking.
Good luck!
AnswerID: 126580
Reply By: Voxson (Adelaide) - Wednesday, Aug 24, 2005 at 09:17
I have made a few enquiries and it seems the auto lock function may have stuck in for a little longer than expected,,,...
No cause for alarm i was told....
AnswerID: 126584
Reply By: fatz - Wednesday, Aug 24, 2005 at 10:24
Voxon, Might be the shear pins in the lokka's. Mine did the same a couple of years ago.
Just a thought.
AnswerID: 126591
Reply By: Twigiee - Wednesday, Aug 24, 2005 at 12:59
...if the hubs arnt locked and its in 2wd then it shouldn't crunch - what about it you have full time 4wd like my 80 series gxl - then crunching?
...voxson - sounds like your GU's going to be fully prepared for the cape york trip next yr! you'll be able to get the rest of us out of trouble!
Twigiee
AnswerID: 126617
Follow Up By: Voxson (Adelaide) - Wednesday, Aug 24, 2005 at 16:43
Hi Twigiee,
It appears that the auto locking feature didnt unlock properly..... (something about driving backwards to dis-engage) and the diff was sort of operating still and the lokka was engaging and dis-engaging as i was doing some tight steering this morning....
All ok now,, just a blonde moment...
The GU is fully prepared as of yesterday.... Fully equipped like the GQ was... I even bought one of those Bushranger Max air compressors,,,, and let me say it is like pulling up next to a service station compressor..
Next May cant come quick enough.....
Are we catching up this weekend?????
FollowupID: 381220
Follow Up By: Twigiee - Thursday, Aug 25, 2005 at 13:10
...bushranger max huh, I'll need to get a second 'dual cylinder foot pump' to keep up now! (one for each leg) ...and two cold beers to prevent overheating!
I'll be there this weekend - i'll give you a call.
Twigiee
FollowupID: 381352
Reply By: Member -Dodger - Wednesday, Aug 24, 2005 at 17:26
Had a similar thing with my GU.
Jack up the front axle with both wheels off the ground then with 4wd disengaged via the gear lever turn each wheel back and forth by hand to make sure that they are unlocked. If they still make a clicking sound then one auto lock has bleep e itself.
If it is a grinding sound then the side you are turning may have a busted cv, but in the nissan this is unusual unless you have been really hammering it.
I finished up by putting in manual hubs which solved all probs.
Cheers Dodg.
AnswerID: 126657
