beachport to robe
Submitted: Friday, Aug 26, 2005 at 20:17
ThreadID: 25901 Views:3630 Replies:5 FollowUps:8
i was wondering what the track from beachport to robe is like? do you drive on the beach? is it boggy this time of the year ect?
Mattie
Reply By: Russel & Mary - Friday, Aug 26, 2005 at 20:28
Bitumen all the way. Will take youhalf an hour. Rus.
AnswerID: 127008
Follow Up By: mattie - Friday, Aug 26, 2005 at 20:36
Hi Russel@Mary
I thought there was a 4wd track linking the 2 towns, i was asked if i wanted to go for the drive with a group of people but was reluctant to take the family if it is a boggy realy rough track.
Mattie
FollowupID: 381567
Follow Up By: Russel & Mary - Friday, Aug 26, 2005 at 20:41
I don't know of a 4x4 track. Nora Crena is sort of half way between and is a lovely little place but I don't recall any tracks either side. I could be wrong though. Rus.
FollowupID: 381571
Follow Up By: Bonz (Vic) - Sunday, Aug 28, 2005 at 15:57
ya rabbit Rus, hahahaha, of course there is a beach/sand track along there and its about a 5-6 hr jaunt, with a friend is better and stay off the beach at the Robe end, its soft as.
FollowupID: 381725
Reply By: Patrolman Pat - Friday, Aug 26, 2005 at 21:08
Robe to Beachport is a great run. Allow 6 hours, the sand can be very soft so take recovery gear. Boggings are common place. Lower tyre pressures to 15-18 psi. There are qiute a few cars in the area usually so help is usually close at hand if needed. One of SAs best beach drives IMO.
AnswerID: 127016
Follow Up By: Member - JohnR (Vic)&Moses - Friday, Aug 26, 2005 at 22:47
Pat, the 15-18 psi is probably at the upper end. It wasn't until I dropped to 12 psi last yearthat I was able to keep above the sand or shell beaches.
Willem is pretty right below, you need to make sure of your recovery gear and good to take some mates to help. As Willem says the dunes above the beach are great to learn tecniques. Make sure you don't drive accross the face of the dunes as some are pretty steep.
Mattie, the worst part of the beaches is the sand those where it is made up of minute pieces of shell about 1-2mm across. They are very light and fluffy to try to drive over and those beaches are best left if you don't want to spend the day digging. Not all are like that, some are pretty solid. The one by the rubbish tip is S O F T.....
FollowupID: 381587
Follow Up By: Truckster (Vic) - Saturday, Aug 27, 2005 at 19:58
yea but your bus weight in at about 12 ton :P
FollowupID: 381664
Reply By: Willem - Friday, Aug 26, 2005 at 21:11
You can drive along the beach to Nora Creina from Beachport and then do a bit of gravel road and then drop down to the beach again at Little Dip CP and drive on to Robe. Depending on the season, the beach can be treacherous, though i haven't been bogged there yet. It is a very scenic drive. You will have to drop your tyre pressures down to 15psi at least and it is advisable to stay high up near the dune edge. Some of the tracks skirt the beach and make for interesting driving over sand dunes.
AnswerID: 127017
Follow Up By: mattie - Friday, Aug 26, 2005 at 21:27
Hi Willem
have u driven on the track at this time of the year- will the beach be to narrow given the winter waves?
Mattie
FollowupID: 381576
Follow Up By: Willem - Saturday, Aug 27, 2005 at 19:31
Mattie
The last time I drove that way was at the beginning of November last year and the tides were not a problem then but I would guess that they may be a bit high now. Best is to check your tide chart and ask the locals at beachport before you go.
FollowupID: 381660
Reply By: Gunnell - Friday, Aug 26, 2005 at 23:55
I was down at Beachport last weekend with a 4wd club doing some prep work for a larger get together. Beaches were VERY SOFT. much more difficult than the many times I have visited in summer. High tide was also very high leaving little room to drive in places. We were actally trying to head from Beachport to Carpenters Rocks but made little ground in 6 hours, constant bogging and winching despie pressures down to 10psi. Not recommended alone!
AnswerID: 127040
Follow Up By: Willem - Saturday, Aug 27, 2005 at 19:50
Tell you what, that run down from Southend along Geltwood Beach was a bugger. I led a convoy of 7 vehicles along the beach with 15psi in tyres
and I was very pleased to be able to get off the beach after about 7km. Had the GQ in 2nd High pumping about 3500 rpm out of the diesel. Two of our party got bogged as when I told them to drop the psi to 15 they decided 20 was good enough. I guess they found out the hard way.
FollowupID: 381663
Reply By: mattie - Sunday, Aug 28, 2005 at 18:20
Thankyou for all the responses i decided not to go in the end, thought i will wait till summer time when the beach is wider. The rest of the group went and had no trouble but i am unsure if they went all the way from beachport to robe, haven't had a chance to catch up properly.
Cheers MATTIE
AnswerID: 127206
