GQ gearbox
Submitted: Monday, Aug 29, 2005 at 22:41
ThreadID: 25973 Views:1710 Replies:1 FollowUps:1
I have an '89 4.2 diesel GQ, which now has a small hole in the passenger's side of the gearbox in-between the transfer case and the main housing of the gear box (I think it's the adapter between the gearbox and transfer case). Something has punched a hole from the inside of the box, dislodging a cylindrical piece of metal (with a square end). The dislodged internal part is partially filling the hole.
I can still select all gears including reverse in 2H, 4H and 4L. There does not appear to be any noises from within the gearbox indicating that something inside is broken ie. no bearing noise and gears aren't hard to select.
Prior to discovering the hole there was a tapping sound coming from near the gearbox. I assumed that it was a stick which I had discovered wedged between a body mount and the floor... Now I am not 100% sure whether the noise that i heard was the stick or the box.
As Patrols generally have few major problems with the gearboxes, I was wondering if any one else has had a similar thing happen, or would be able to shed some light on what may have happened?
I am unwilling to drive it anywhere at this stage since the entire contents (gear oil) have emptied onto my garage floor.
Reply By: cokeaddict - Tuesday, Aug 30, 2005 at 08:27
Its pointless owning a vehicle u cant drive. get the box looked at and fixed. Prepare yourself in advance, shop around and price a second hand box from a few locations then get a quote to have yours fixed. Bottom line is.... it has to be sorted out. Personally, I wouldnt keep the case if it had a hole in it. You just dont know how much stress that point will handle off roading.
Ange
AnswerID: 127400
Follow Up By: Truckster (Vic) - Tuesday, Aug 30, 2005 at 09:19
Im not sure what hes asking.
it has hole in it, leaked oil everywhere, making noises before hole was there...
to me its a no brainer to remove the box, and replace.
try outerlimits4x4.com theres a manual gearbox on there forsale or 2, Giantracing is the dude selling and also another bloke - you may have to look round a bit.
FollowupID: 381901
