Radio Wiring - GU Patrol
Submitted: Tuesday, Aug 30, 2005 at 08:11
ThreadID: 25979 Views:16365 Replies:5 FollowUps:4
G'day all. I own a 2005 Gu Patrol (3.0L), and I am about to install an aftermarket Alpine CD player and Uniden UHF in the factory head unit position. Does anyone know what wires are what?! Also, the factory aerial plug is a two-pronged arrangement, whereas the new CD player is the standard single plug - any advice there?? Thanks in advance.
Reply By: Leroy - Tuesday, Aug 30, 2005 at 09:20
I got my wiring diagram from the install doctor web site but you now need a pw but there is another but you will have to look through the pages but I'm sure there will be one that matches. You will need to pull your stereo out first.
http://carstereohelp.net/wireharness_Nissan1.htm
The factory antenna twin plug lead connects to the antenna in the kick panel. Buy an antenna extension lead and replace the lead that goes from the kick panel to the radio.
Leroy
AnswerID: 127406
Reply By: Truckster (Vic) - Tuesday, Aug 30, 2005 at 09:28
If your going to all that trouble, put an MP3/WMA player in there....
You can buy adapter plugs for Alpine to Patrol - or I could for my GQ, thats how they wired it when I got my MP3 player installed.
AnswerID: 127407
Follow Up By: Scott_05 - Tuesday, Aug 30, 2005 at 09:30
Thanks Truckster, it is an MP3/WMA player. I haven't been able to find the adapter plug for the new patrols. I would prefer using one of those than cutting the factory plug off.
FollowupID: 381906
Follow Up By: angler - Tuesday, Aug 30, 2005 at 20:30
I am having similar problems and have found a supplier. They are wgholesale however and will not sell to the public.
They have a web site that displays their dealers.
The aerial converter is AP348A and the power thing I think is APP0120
Web site www.aerpro.com
FollowupID: 382023
Reply By: DEANO WA - Tuesday, Aug 30, 2005 at 10:19
just put an alpine in my GU, antenna should plug straight in (I installed a long range on bull bar). the wiring is easy black =neg, red?=pos, and i think its yellow?=constant pos for memory. to check just use a test light.
AnswerID: 127413
Reply By: Bullwinkle - Tuesday, Aug 30, 2005 at 10:58
Deano; What's your "long range aerial" like? Does it improve your reception much? And where did you get it? Ta...
AnswerID: 127416
Follow Up By: DEANO WA - Tuesday, Aug 30, 2005 at 12:05
dont know yet, havent gone long range but leaving karratha for perth in 3.5weeks so should know then
FollowupID: 381928
Follow Up By: DEANO WA - Tuesday, Aug 30, 2005 at 12:07
sorry, i bought it at a auto parts shop up here but you can get them anywhere??????????????????
FollowupID: 381929
Reply By: dozerdude - Tuesday, Aug 30, 2005 at 22:19
you can buy the aerial plug arrangement from strathfield for about 20 bucks i think it was when i change the radio in my gu in march.
AnswerID: 127546
