fuel pumps
Submitted: Tuesday, Aug 30, 2005 at 23:55
Rob38
I heard a while back of a
fuel pump for jerry cans and 200L drums that uses a compressor to presure the drum and push
fuel out. Does this still work and where do you get them?
Reply By: muzzgit (WA) - Wednesday, Aug 31, 2005 at 00:12
Its not a
fuel pump, just physics. On a 200l drum you take off the bung and drill hole in it big enough to weld or bronze a tyre valve. When you put compressed air in, this forces the
fuel up the hose into your
fuel tank.
Don't use the valve, just the fitting, so you can release the pressure as you need.
I have used one of them on a drum with one of those
hand pump jobbies. Saves bit of effort if you need to move all the
fuel.
127565
Follow Up By: muzzgit (WA) - Wednesday, Aug 31, 2005 at 00:14
Forgot to mention that the pipe or hose you use for filling must be sealed and must reach the bottom of the drum.
382076
Follow Up By: Rob38 - Wednesday, Aug 31, 2005 at 00:26
This sounds alright but the drums are full, welding or braising a valve would be interesting. We get the drums full. I will look for the Tanami Pump.
Rob
382078
Follow Up By: muzzgit (WA) - Wednesday, Aug 31, 2005 at 00:28
It does say "take off the bung and drill a hole in it"
382079
Reply By: Harrow - Wednesday, Aug 31, 2005 at 00:18
Its called the Tamami Pump and you caan have a look at on at ARB
Harrow
127566
Reply By: bob - Thursday, Sep 01, 2005 at 20:41
Try www.outbackin.com for details on the 200L drum pump and the 20L jerry can pump. Recommended price is $200. They often appear on ebay and you could pick one up for half that price.
127810
