back doors on my gu patrol
Submitted: Thursday, Sep 01, 2005 at 12:27
jt
Hi everyone I have a 98 gu patrol i have a rattling noise in the back cabin area i think it is the back doors it is driving me crazy trying to find it has anyone had this problem if so how did you fix it.
Reply By: David - Thursday, Sep 01, 2005 at 12:37
Know exactly what you mean. After I picked up my 2003 (S/hand) GU it started. Spent the first weekend pulling apart all the doors, tightening everything, tying cables etc etc. The result was absolutely zero. the rattle still there.
Was talking to a neighbour the following weekend and we were standing behind the vehicle. He just put his hand on the backdoor to lean against and I heard a click. Believe it or not the door was not fully closed. Have not made any adjustments but just make sure I close it solidly.............hence now no rattle
127752
Reply By: tima - Thursday, Sep 01, 2005 at 13:15
Had something similar with my 00 model. Found both the door had to be shut quite hard, and that the tack weld on the hinge inside the body had come adrift - ended up inserting some bolts to hold it all together
127760
Follow Up By: jt - Thursday, Sep 01, 2005 at 13:28
yes
the spot welds broke i have rewelded them i also shut the doors quit hard if i shut them any harder i may have to get them of the front seats.
382337
Follow Up By: V8Diesel - Thursday, Sep 01, 2005 at 15:12
Same with my '98, spot welds broke.
382373
Follow Up By: Waynepd (NSW) - Friday, Sep 02, 2005 at 09:12
Had the same spot weld break on my 98 DX, drilled and screwed through it and so far the noise has gone. But that noise was only an issue when opening or closing the rear doors.
The other source of noise i had when i first got the truck came from the plastic inner guard beneath the fuel filler pipes, which sounds to me like what your talking about. It was a knocking sound that happened as I drove along on rough roads, smooth roads it didn't matter.
It depended a bit on the speed i was travelling because the wind would be what was moving it around. It drove me nuts for awhile, I even had a mate sit in the cargo area listening as I drove.
One day I was laying under there having a look around (as you do) and bumped it with my hand and it was the "noise". One self tapper later and I was in driver's heaven......It's a protective cover for the filler pipes i assume and it is fixed to the body with plastic thingys, 2 of which had broken off.
good luck with it
382493
Reply By: Notso - Thursday, Sep 01, 2005 at 18:15
Yeah my 2000 GU did the same till I found the fix. First find a rather large Palm Tree. Reverse into it just hard enough to cut through the spare tyre cover.
Bingo, all fixed???. Tried to sell the fix to Nissan but for some reason they weren't interested???
127792
Reply By: Shaker - Thursday, Sep 01, 2005 at 19:10
I had the same thing in my Terrano 2, nearly drove me crazy ....... turned out to be
the spot welds holding the internal reinforcing bracket for the door mounted spare wheel, so I bolted where I could, & used 3/16" monel pop rivets elsewhere.
@ outback trips later including the Simpson & no further problems!
127798
Follow Up By: angler - Thursday, Sep 01, 2005 at 19:50
The rattle in
mine turned out to be the number plate bady fitted. Now all I have to do is stop the bloody squeak when you open the big door.
382420
Follow Up By: madcow - Friday, Sep 02, 2005 at 12:09
try chain lube
382517
Reply By: Patrol22 (Queanbeyan - Friday, Sep 02, 2005 at 12:44
After fixing the umpteenth rattle in
mine - I just turned the radio up and forgot about it.
127916
