Grazierbill's canopy
Submitted: Thursday, Sep 01, 2005 at 15:16
ThreadID: 26039 Views:2246 Replies:5 FollowUps:4
Anybody know Grazierbill? I'm trying to get in contact with him regarding his weldmesh canopy.
Reply By: Truckster (Vic) - Thursday, Sep 01, 2005 at 16:27
http://203.147.170.134/Members/ViewRig.asp?RigKey=45812&Layout=6
maybe contact EO Dave, see if he can make contact for u, and get him to reply back.
AnswerID: 127781
Reply By: Member - Grazierbill - Thursday, Sep 01, 2005 at 19:04
Austravel
What would like to know. ? Give me your email address and I'll try and help you.
With regards.
Bill
AnswerID: 127797
Follow Up By: Austravel - Friday, Sep 02, 2005 at 15:49
Hi Bill,
The email address is r.kearney(at)cqu.edu.au
Was hoping you could send me some picture of the overall set up and some close ups of different sections like the mounting points, strut connections, lock/handle set up etc, etc. The more the better as it will stop me from reinventing the wheel. Plus any other help you can give like were to get the air vents from etc.
Thanks heaps.
FollowupID: 382567
Reply By: Wisey (NSW) - Thursday, Sep 01, 2005 at 19:36
Austravel.
You've probably seen post 20716. if this helps.
I'm going for the same thing using 3 screen doors with the expanded mesh and possibly a solid roof draped with canvas.
Andy
AnswerID: 127799
Follow Up By: Austravel - Friday, Sep 02, 2005 at 15:54
Thanks Andy, have you started yours yet?
FollowupID: 382568
Reply By: Wisey (NSW) - Friday, Sep 02, 2005 at 20:32
Austravel
Not started building YET ;) still gathering ideas and bits. I've got a selection of alloy or steel pipe, canvas, 3 second hand expanded mesh doors. Side doors will be close for size but will have to resize one for the back. It's on a wishlist with dual batteries NEXT, reinstall compressor(moved for D Bat'), raising tray height 50mm (for better fuel flow in), install pump for water tank, and on and on..........slide out kitchen........and on........install cruuuuise control...........Bills unit looks the goods, with a little of John (Vic) and .................drifta style of kitchen.........and ?? So Many possibilities.
I'll tag your addie from this thread and keep in touch if thats ok?
Andy
AnswerID: 128010
Follow Up By: Austravel - Friday, Sep 02, 2005 at 21:13
Know what you mean. Have Just finished one project, sold it and now starting another. Need a kick in the a.. for not thinking about it properly. Aaah well live and learn. One thing I'd suggest is be very, very carefull of the weight, it's very easy to get to the overloaded point. My GU ute with fuel, 80l of water, two spare wheels and two people is close to 3t so leaves only 400kg.
I'll let you know what I do and please do the same.
Are you saying that the ordinary home security screen door will suit?? If so I'll have to have a look around.
Ray
FollowupID: 382615
Reply By: Wisey (NSW) - Friday, Sep 02, 2005 at 22:03
Ray
Yep, HS Door. For mine it suits my tray size just right, H X L. (Lux xcab). I'll prob' build canopy to suit door size. Steel is so easy to work with but alloy is the better for weight. I have a very strong and heavy steel tray (with dropsides which I don't want to use). Roof setup will be fairly solid to carry extras
Will need to hook up with canvas man to assess location of zippers in relation to doors opening/closing allowing for weather proofing etc and on and on......:)
Whats ya rig?
Anything from the Grazier?
awise181 at aapt dot net dot ayou
AnswerID: 128027
Follow Up By: Austravel - Monday, Sep 05, 2005 at 09:25
A GU patrol.
FollowupID: 382965
