Isolators that DON'T use Solenoids
Submitted: Saturday, Sep 03, 2005 at 08:55
ThreadID: 26090 Views:3491 Replies:6 FollowUps:7
I'm trying to get an understanding of the Dual Battery Isolators that are available.
Does anyone know of an Isolator that uses an Electronic MOSFET to provide the connection between the two batteries, rather than a Solenoid or Relay.
The Jaycar/DickSmith KIT is the only one I have come across.
Reply By: Member - Jeff M (WA) - Saturday, Sep 03, 2005 at 11:18
I used the kit you are talking about for about a year, but I have gone back to the Solinoid/Relay type. Even though they reckon there is no voltage drop accorss the mosfet deisgn I was still getting some. The relay give no visible voltage drop on my meter and is more reliable IMHO.
AnswerID: 128076
Follow Up By: Mike DiD - Saturday, Sep 03, 2005 at 16:36
The Silicon Chip Design ADDS IN a 0.1 Ohm resistor (1 volt at 10 Amps) to provide protection against reverse flow through the MOSFET Diode.
FollowupID: 382715
Reply By: at4x4 - Saturday, Sep 03, 2005 at 13:03
We are importing one at the moment which is similar technology, but also switchable, stackable, and 300 amp + for winching etc
powergate
Some also use voltage sensing relays.
AnswerID: 128093
Follow Up By: Mike DiD - Saturday, Sep 03, 2005 at 16:34
Do you also import the MobiArc Alternator Welders ?
FollowupID: 382714
Follow Up By: Member - DOZER- Sunday, Sep 04, 2005 at 20:43
I have one...took it off for other accessories..
Andrew Wollongong
0408965433
FollowupID: 382912
Follow Up By: at4x4 - Monday, Sep 05, 2005 at 07:37
We do,
just finalised all the AS and legal jargon, and we have set up dist in 4 staes.
FollowupID: 382956
Reply By: ACDC - Saturday, Sep 03, 2005 at 13:39
Stick with a solenoid or relays no problems the mosfet type have problems drain back.
AnswerID: 128100
Reply By: Leroy - Saturday, Sep 03, 2005 at 13:52
Piranah is another.
Leroy
AnswerID: 128102
Follow Up By: gqpat - Saturday, Sep 03, 2005 at 19:32
Try Ashdown electrical wholesalers or your local autoelect .TRANSPO an american name sell many types of true batt isolaters size is dependant on alternator output as they split the output current to each batt depending on which one requires it .They were also imported by Baxters auto elect wholesalers..
FollowupID: 382744
Reply By: Member - DOZER- Sunday, Sep 04, 2005 at 20:46
There is one isolator that swaps batteries and charges them seperate rather than joining them together....can anyone assist in the name...they do 2 or 3 batteries...joining a low battery to a charged one lessens the life of both plus the amps flow is unrestricted till they even out in volts.
Andrew
AnswerID: 128266
Follow Up By: Mad Dog (Australia) - Sunday, Sep 04, 2005 at 21:37
The high range Rotronics model does that. Info on the their website rotronics.com.au....I think
FollowupID: 382926
Follow Up By: Member - DOZER- Sunday, Sep 04, 2005 at 23:21
Thats them......they charge each battery independantly, starting at the main...which makes more sense than just joining the batteries together once main reaches charged stste....
I installed a second alt from an old datto and ran 2 complete systems....cheaper than an isolator, better in many ways, but not easier.
Andrew
FollowupID: 382946
Reply By: 4145derek - Wednesday, Sep 07, 2005 at 21:33
Try the Bi-80 availbale on ebay. Best Fully automatic unit available at under $100
AnswerID: 128960
