Sunday, Sep 04, 2005 at 23:26
Thank you for that glowing introduction Mr Lucy (he wanted to call himselfl "Lucky", but stuffed up....he can't spell anything bigger than a four letter word..hahaha). Why does he class himself as "Lucky"?....cos most days (aw
well 2 out of every 4 anyway), his yota will start after about only half an hour of cranking (aka "winding up the rubber band").
Anyway, in answer to the question at hand......Yes I have the Counteract system fitted. I did it myself with one coupler pad on the GU's firewall and the other inside the rear quarter panel. As to whether it works or not? all I can say is that the vehicle is 5 years old, has done a relatively small amount of beach work, does not get washed anywhere near as often as it should be (about 3 times a year) and I have not seen any
sign of any rust in it to date.
Hope this helps.....(Nothing will help Mr Lucky(;-))
Roachie
382949
