Nissan Patrol 2.8 on gas
Submitted: Tuesday, Sep 06, 2005 at 19:45
blackwrx
I am thinking about putting the nissan on gas with the price of
fuel etc, but I am only really interested in doing this if I can fit the gas
tank under the car. Does anyone kniow if this can be done and how much it should roughly cost to convert the nissan to gas?
Cheers!
Reply By: Exploder - Tuesday, Sep 06, 2005 at 20:09
I am assuming that you are talking about running it solely on gas witch can’t be done as the 2.8 is a diesel engine and is missing the necessary component’s to ignite the gas air mixture. However you can run a gas and diesel mixture witch is meant to give better power and
fuel economy but then you need to pay for 2 loads of
fuel so kind of defeats the purpose.
Diesel engines ignite the
fuel air mixture by use of compression and the heat caused by compressing the air so when the diesel oil is injected just before top dead centre the compression and heat of the compressed air ignites the diesel oil so as a result diesel are missing all the electrical component’s that are on a petrol engine.
128703
Reply By: rolande- Tuesday, Sep 06, 2005 at 20:30
MQ/MK 2.8??
If so can fit
tank where spare wheel is, will need to relocate spare wheel to back tailgate, same as they do with 'cruisers
Hope this helps
Rolande
128708
Reply By: Truckster (Vic) - Tuesday, Sep 06, 2005 at 21:15
well depending on which petrol motor you wish to put in there to replace the diesel engine, most engine conversions are $10k...
Then around $3k for LPG conversion too.
128727
