12 volt power cable for Uniden UH075 Handheld
Submitted: Wednesday, Sep 07, 2005 at 14:03
ThreadID: 26241 Views:4895 Replies:6 FollowUps:1
Hi all,
Recently bought a Uniden UH075 5 watt Handheld UHF.
The radio looks the goods and I will be giving it a workout over the next few weeks on upcoming trips however I have a question concerning power. I need to be able to recharge the thing in the vehicle but can only use 240v. I have an inverter but as yet it is not installed and is a bit of a pain to set up. It would be much easier while driving to be able to use a ciggy lighter adapter in the same way as I do with my Mobile phone.
The Radio has a custom Lithium Ion Battery that fits into a fairly bulky drop in charger. The charger accepts 12 volt DC from an AC Adapter but the guys at dick smith tell me it is a weird size tip. They say they may be able to build me a custom cable.
Can anyone with this radio tell me if they have found a 12 volt cable that fits?? Or advise how they charge on the go.
Muddy
Reply By: Member - Roachie (SA) - Wednesday, Sep 07, 2005 at 14:19
Muddy,
Just get ya finger out and wire up the bloody inverter;;;; problem solvered (;-))
Ya got nuffin better to do in ya spare time anyway.......
AnswerID: 128864
Reply By: GGtriton - Wednesday, Sep 07, 2005 at 17:34
Muddy,
Have the same hand held and purchased an adaptor from here.
http://www.tradingdirect.com.au/cache/header-52public__0-0.html?cache=no
Hope this helps.
AnswerID: 128896
Reply By: res.q.guy - Wednesday, Sep 07, 2005 at 17:51
Hi Muddy
The other option would be to purchase a smaller inverter that plugs into a cig. lighter socket.
You could use this for video chargers, 240v shavers, and similar.
You can get them from Jacar from about $50
Neil
AnswerID: 128901
Reply By: MartyB - Wednesday, Sep 07, 2005 at 17:57
Hi Muddy, I have just got one & for an extra $50 I got a 12v lead. It is simply a lead for cig lighter to a plug that plugs into the existing charger.
Do you use the standard aerial when in the car or an external one? I am thinking of trying an external aerial to give better range.
from Marty.
AnswerID: 128906
Reply By: Harrow - Wednesday, Sep 07, 2005 at 17:57
Hey Muddy
Dont make a simple job look difficult.
I have one that I charge off the vehicle 12V in the cradle I will check when I get home exactly what I have done, but I believe it is simple as.
Check the output of the 240v charger I think it was 12V so I simply got a plug from DS that pluged into the cradle and wired it into 12V
Will confirm later
Harrow
AnswerID: 128907
Follow Up By: Harrow - Thursday, Sep 08, 2005 at 15:18
Hi Muddy
Yep as I thought
A plug from Dick Smith into the cradle and directly wired into 12V, my cradle is permanently mounted in the car
FollowupID: 383577
Reply By: vitara - Thursday, Sep 08, 2005 at 14:31
Hi there Muddy 'doe, mate I just looked up your rig profile sounds pretty well set up only one question, why did you go and buy a hand held uhf when you already have 1 in the 4by before buying the cargo barrier. I didn't see the hand held on your wish list. I hope you don't have kids in the back ???? Maybe you should have a read of post 26181 Regards Vitara Ps please dis regard if you have bought one but just havn't updated your rig profile
AnswerID: 129071
