Tuesday, Sep 13, 2005 at 09:13
G'day, I sent this reply to Angler a few days ago. Before you start dropping pressures, it is important to get the normal road pressure right first.
Here's my 3 cents worth. I just bought a 2004 GU III Patrol 3.0TD manual, and had the same questions. 27,000k's and the rear tyres are nearly smooth in the centre. I have Bridgestone Dueller A/T D693's in 265/70-16 fitted.
I started by ringing the local Bridgestone dealer and asked the question, then the local Bob franchise, and surprise, surprise, surprise, got two different answers. Maximum pressure was anywhere between 50 and 65 psi.
Time to get technical. An email to Bridgestone Australia was quickly replied too. Maximum tyre pressure - 36psi !!! So from there I went and got the axles weighed (full
fuel tanks and girlfriend, and myself in the vehicle, and it weighed 1,320kilo's - front, 1,240 rear) and from there it was simple math.
The equasion went like this (front) - weight (!,320) divided be 2=660. Maximum tyre load for the D693 is 1,120 kilo's@36psi, 36 divided by 1,120=0.032143. So 660 multiplied by 0.032143=21.2psi. Now I added another 5psi for high speed running (110kph) and with 26 psi (cold) in the front it steers nicely, doesn't roll about overly, and give a smooth and comfortable ride. The same equasion was done for the rear and I run 24psi (cold) there. This is the best starting point.
From here I will monitor heat build up - I am aiming for a 4psi pressure build up after an hour of highway running. If I get more than a 4 psi build up, I will increase the cold pressures by 2psi each time until I do. Conversely if I get less than 4psi, I will start dropping pressures.
Obviously loading the vehicle will change all these figures, but it does give a good starting point. Hope this helps. Cheers.
129820
Follow Up By: Graham & Ann - Tuesday, Sep 13, 2005 at 22:08
4psi rule has been around a long time (most car tyres were a lot smaller then back then), maybe a 6psi rule could possibly be more suited to the larger tyres fitted on todays 4x4s..
384417
Follow Up By: Member - MrBitchi (QLD) - Wednesday, Sep 14, 2005 at 08:20
Mate, think your logic is a bit flawed. If you're going to do a calculation like that surely you should start at the MAXIMUM recommended pressure for the tyre. Using 60PSI as the max gives 35PSI....
26/24 WILL give a smooth comfortable ride but will also drastically increase your rolling resistance, and therefore increase
fuel consumption and generate far too much heat. IMO you a running way too low for highway use.
FWIW I run 36/34 on my Pajero (+2psi when fully loaded). I air down to about 28 for gravel roads.
Cheers....
384468
