BF GOODRIDGE TYRES ON A GU PATROL
Submitted: Tuesday, Sep 13, 2005 at 21:12
ThreadID: 26433 Views:5268 Replies:6 FollowUps:7
I CURRENTLY RUN BFG's 265/75 AT ON MY PATROL. I AM CONSTANTLY TOLD THAT THE 40PSI I RUN IN BOTH FRONT AND REAR TYRES TOO HIGH.
I HAVE HAD A PAJERO, FORD EXPLORER AND NOW THE GU PATROL, AND HAVE FOUND WITH MOST TYRES 40 PSI WORKS WELL, ALBEIT A LITTLE ROUGH WITH NO LOAD. TYTRE WEAR IS PERFECT. ANY FEEDBACK PBS127
Reply By: Exploder - Tuesday, Sep 13, 2005 at 21:33
I run 46psi in my cooper AT’s on the black top and did the same with the old set as well have had 0 problems, Ford Explorer
I just use the stamp on the tyre as a guide I.E Cooper stamp say’s 50Psi cold inflation temp.
AnswerID: 129960
Reply By: pbs127 - Tuesday, Sep 13, 2005 at 21:38
THANKS FOR THE INFO. I'LL STICK WITH THE HIGHER PRESSURES, THEY WORK FOR ME AND TYRE WEAR IS PERFECT PBS127
AnswerID: 129962
Reply By: Member - Trevor R (QLD) - Tuesday, Sep 13, 2005 at 21:47
pbs127,
You pretty much answered your own question. If your pressures give you good tyre wear (within manufacturers specs) then you are on to a good thing and stick to it.
For arguement sake I agree with the pressures you run as that is similar to my own preference, but I can go a tad higher when I really load up. 45psi not uncommon in my rig. Dueler A/T's averaging 70000km a tyre. The newer the tyre the less km I'm getting lately, maybe $hit rubber these days ?? Am due for 2 more soon not sure if I'll go Duelers again or not.
Regards Trevor.
AnswerID: 129964
Follow Up By: pbs127 - Tuesday, Sep 13, 2005 at 21:56
THANKS TREVOUR, I LIKE YOUR RIG BUT YOU LOOK TO YOUNG TO DRIVE PBS127
FollowupID: 384413
Follow Up By: Member - Trevor R (QLD) - Tuesday, Sep 13, 2005 at 22:11
They say it is often safer on the road than in the playground.
NOT WITH ME DRIVING DAD'S CAR.
Cheer's Trev Jnr.
FollowupID: 384418
Reply By: Peter McGuckian (Member) - Tuesday, Sep 13, 2005 at 22:04
I beg to differ here. I have 275/70s on my 3.0lTdi GU and use about 34 front 38 rear. Then lower on gravel and dirt. Lower still on sand. Have done close to 100k on first set.
I think 40+ is just too forma ride round town and far too high where there are stones. Puncture waiting to happen.
AnswerID: 129969
Follow Up By: Member - Trevor R (QLD) - Tuesday, Sep 13, 2005 at 22:15
Peter,
I got 110km out of my first set as well but haven't nearly got close to that since.
As I said if it works for you, stick to it. I don't do much trail work therefore higher pressures OK for my circumstance.
Regards Trevor.
FollowupID: 384421
Reply By: Peter McGuckian (Member) - Tuesday, Sep 13, 2005 at 22:05
I think 40+ is just too firm a ride round town and far too high where there are stones. Puncture waiting to happen.
AnswerID: 129970
Follow Up By: pbs127 - Tuesday, Sep 13, 2005 at 22:12
Peter, thanks for the reply. I should have been a little clearer with my question.
I do about 1600k a week on the bitumen and about 100k on gravel roads. If Ii am doing a long trip on gravel I generally drop 10 psi
thks pbs127
FollowupID: 384420
Follow Up By: Peter McGuckian (Member) - Tuesday, Sep 13, 2005 at 22:27
I can't figure out why that posted twice - thought I'd fixed the typos.
I think as a general rule you will get a higher mileage with the higher pressures but I thought the ride and steering was affected.
FollowupID: 384424
Follow Up By: Truckster (Vic) - Wednesday, Sep 14, 2005 at 10:44
down to 10psi on gravel roads? I smell something
FollowupID: 384490
Follow Up By: Leroy - Wednesday, Sep 14, 2005 at 10:47
'I generally drop 10 psi '
40-10=30
Looks a little on the high side by a few psi.
Leroy
FollowupID: 384491
Reply By: joc45 - Wednesday, Sep 14, 2005 at 10:27
At the opposite end of the scale, I ran my first BFGs at the pressures recommended by Nissan, and found that they were wearing significantly on the outsides; ie, underinflated. I now run about 33 in the front, 38-40 in the back and get good wear.
And I drop the pressures about 5psi on the gravel, and have had no failures (yet).
Gerry
AnswerID: 130023
