Door strut alternative
Submitted: Thursday, Sep 22, 2005 at 09:37
Austravel
I've built a canopy for a patrol tray back similar to a member on this site. Basically a canopy with steel doors covered in weldmesh. I didn't want to go to the expense of struts, any ideas on alternataives. Was thinking of something mechanical like that used in brief cases.
Any ideas??
Reply By: Johnnotoo - Thursday, Sep 22, 2005 at 10:13
Hi Austravel
Yacht /boat chandlery shops such as Whitworths sell a coiled spring that holds hatches etc open and you push/kink spring to lower. Very simple and works
well , or you could just buy any spring with a fixing point each end and make your own. Spring is never under any tension. Holds hatch/door etc open just by it's length and rigidity (so it is under compression I guess you could call it whilst door is open)
You would want a tightly coiled spring around say a foot long and possibly up to an inch or so thick. If door is heavy, then 2, one each side.
Hope this makes sense
johnnotoo...............
131324
Follow Up By: Austravel - Thursday, Sep 22, 2005 at 13:47
Thanks, never knew they even existed.
385708
Reply By: Russel & Mary - Thursday, Sep 22, 2005 at 12:30
Hi Austravel, I've made two canopies and both times have used old gas struts off a car bonnet. One each side is adequate, even though they won't hold a heavy bonnet. Go to your local mechanic and he's bound to have a few old ones just for this very purpose or to a wreckers and pay about 30 bucks each complete with the little bolt on brackets each end. Dead easy to fit and are the ducks' guts. Rus.
131340
Follow Up By: Tuff60 - Thursday, Sep 22, 2005 at 12:50
On Rus's idea, if you use Ford XD/E/F bonnet struts, they would be about the cheapest from wreckers. $30 would buy you the bonnet as
well, maybe the whole front end. :)
385706
Follow Up By: Austravel - Thursday, Sep 22, 2005 at 13:48
Thanks, just rang up $17.
385709
Reply By: simple - Thursday, Sep 22, 2005 at 12:52
hey austravel, any chance of you putting some photo's on the site or emailing them. are you involved in the yahoo traytop
camping group? link text
131345
Follow Up By: simple - Thursday, Sep 22, 2005 at 12:56
i meant to put "traytop
camping group" in there instead of "link text" maybe i should pay attention when i type
385707
Follow Up By: Austravel - Thursday, Sep 22, 2005 at 13:49
I do visit the site.
Can send you pics of the canopy let me know your address.
385710
Follow Up By: simple - Thursday, Sep 22, 2005 at 21:00
j.sim@ozemail.com.au
that's my email. i'd really appreciate it as i'm about to build one on my patrol.
thanks
385752
Reply By: traveller2 - Thursday, Sep 22, 2005 at 15:18
If you have small doors the boot struts from Falcon's work
well, they also have and eye either end and can be mounted between two bolts rather than a ball fitting.
They close to about 6 inches and extend to approx twice that. 5/16 or 8mm bolt works fine for mounting.
131356
Follow Up By: Austravel - Friday, Sep 23, 2005 at 09:24
Thanks for that, will check them out on the weekend. Just checked and can get them for $11. If they suit will be much cheaper than ready made units to suit.
385797
