GU exhaust to give away
Submitted: Friday, Sep 23, 2005 at 10:05
ThreadID: 26695 Views:1642 Replies:3 FollowUps:4
I have a complete GU exhaust system to suit a tray back to give away. It's not new but is still in good condition. Only replaced to upgrade. If you want it get back to me.
Reply By: Coyote - Friday, Sep 23, 2005 at 10:26
Where are you and what size/type of engine was it. (Or doesn't it make a difference) Now thats an ignorant question isn't it.. (I have a 2.8 Gu Wagon and I need the 1st Half to be replaced.. ) Cheers
AnswerID: 131474
Follow Up By: Austravel - Friday, Sep 23, 2005 at 10:59
From a 4.2 turbo diesel ute. Not sure if it will be the same. Check it out and get back to me if you want it.
FollowupID: 385810
Reply By: Coyote - Friday, Sep 23, 2005 at 11:01
Where are you? If it involves signifigant postage may not be worth chasing up.. Cheers..
AnswerID: 131483
Follow Up By: Austravel - Friday, Sep 23, 2005 at 11:03
Rockhampton
FollowupID: 385811
Reply By: Coyote - Friday, Sep 23, 2005 at 11:14
Cheers.. I reckon the postage (or courier more to the point) would cost me more than it's wrth as I'm in Adelaide.. Good on you for offering it though Cheers.. I assume yo've gone the 3 Inch upgrade? let me know if it makes much difference as I havebeen considering doing it for my 2.8. Did you go extracotrs as well and if you don't mind me asking what was the damage$$ Cheers
AnswerID: 131487
Follow Up By: Austravel - Friday, Sep 23, 2005 at 11:58
No dramas.
The changes made a huge difference, mainly the replacement dump pipe. Cost was close to $1k and well worth it.
FollowupID: 385825
Follow Up By: Member - Roachie (SA) - Friday, Sep 23, 2005 at 16:18
Coyote,
You can't go for extractors too if you've got a turbo (which, being a 2.8l, yours obviously is). As far as Austravels ute is concerned, it could be a non-turbo'd version; except that in view of him mentioning the "dump pipe", which indicates his is a 4.2TD (ie: the dump pipe is the expensive bit that joins the turbo to the rest of the exhaust).
Roachie
FollowupID: 385852
