air compresser\pto
Submitted: Saturday, Dec 21, 2002 at 01:00
robert
do you no were i can get a air compresser running of the pto for a hj75 and 100series
Reply By: OziExplorer - Saturday, Dec 21, 2002 at 01:00
How many CFM do you want?
10053
Reply By: Eric - Saturday, Dec 21, 2002 at 01:00
Robert.
THe pto speed at idle is only about 100 RPM, to get a compressor to do anything useful at that speed you would need a large industrial unit, it may be to big to fit under the floor. an early model milking machine would pump at that speed but only about 20 psi. Eric.
10061
Follow Up By: Oziexplorer - Sunday, Dec 22, 2002 at 01:00
Eric you can buy PTO with different gear ratios. You can also buy air compressors with an SAE mount that will direct couple. Just dpends on what size air compressor you want. You need deep pockets for these air compressors.
5260
Reply By: Hedonist - Saturday, Dec 21, 2002 at 01:00
PTO on a 100 series????? I didn't know there was one!
10063
Follow Up By: Bob Y. - Sunday, Dec 22, 2002 at 01:00
Hedonist, Fits on nearside of transfer case, in same place as other models. Merry Christmas
5275
Reply By: leeand deb millard - Sunday, Dec 22, 2002 at 01:00
rob ,hi this has nothing to do with pto's but a car rotary refrigerated comppressor like you use for your air conditioner can be used as an air compressor my father has used one and connected it to a gas bottle with a pressure cut out switch and it works very
well,it could be mounted of the engine and use the clutch to switch it on or off
10066
Follow Up By: Rowdy - Sunday, Dec 22, 2002 at 01:00
I would be VERY careful using an old gas bottle such as an LPG bottle unless it has been purged correctly with an inert gas, as compressed air and LPG can be the recipe for a big bang.
Rowdy
5264
Follow Up By: Truckster - Sunday, Dec 22, 2002 at 01:00
You can buy truck air tanks from wreckers for $40 why would you risk your life on a bleep ty old gas bottle?
Theres also 100 threads on this here if your interested search the archives.
5280
Reply By: leeand deb millard - Monday, Jan 13, 2003 at 23:21
sorry rowdy and truckster was only trying to let him know that a a/c compressor will pump air very
11243
